T O35 Pressure plate
D Roberts
04-26-2001 18:44:21
I have recently split my 35. The throw out bearing seized up causing damage to the bearing carrier along with shaving off the nubs from the release finger on the pressure plate.This tractor shows it has 1400 hrs.It uses the early model Auburn dual clutch with the stamped release levers. Has anyone replaced the levers? I am considering doing this unless it is important to replace the whole assembly.I have the gauges that the IT shop manual shows.The clutch was working fine before the bearing went out. $40.00 for replacement levers vs. $200.00 plus for a pressure plate that I may not need.All advice is welcome.Thanks Darren Roberts
bobby
04-26-2001 19:49:03
 Re: T O35 Pressure plate in reply to D Roberts, 04-26-2001 18:44:21
You can replace the levers. If the TO bearing was seized it was a good bet that the levers were riding all the time. A bad sign the main plate is worn. visually inspect and if it all seems ok then reset to specs. be sure to lube the splines with lubra-plate or anti-seeze. this will make the clutch much smoother to operate.
