Oil f0r TO-20
Rich Zlattner
04-25-2001 07:47:52
I'm ready to change the oil on my TO-20 for the first time. I know that I should use non-detergent oil, but what grade oil do I use? Also, does any parts store carry non-detergent oil? What do I use to clean the oil filter?
Thanks!!
Rich
dennis
04-25-2001 11:04:35
 Re: Oil f0r TO-20 in reply to Rich Zlattner, 04-25-2001 07:47:52
use any good multi vis oil such as 10w30, etc. Detergent oil is acutally better as it will keep the gunk in suspension and flush it when you change the oil. Just make sure that you change the oil after a few hours of running, then again after a few hours of running to get the accumulated stuff out. After it's been changed a couple times, then you can go to a regular changing schedule. Remember, it's just an engine like any other.
Duner Wi
04-25-2001 10:34:40
I would purchase a new filter from MF dealer. Part# 830910m91 price in 1998 $7.89.Spare gasket for the filter cover is nice to have around in case you need one. Part #1750269m1 for the gasket. This is for the TO20 with a cont. Z120 engine. Auto parts store should have or be able to get the filter. Baldwin # is T44M if I remember correctly. Gasket for the filter cover are not quite so easy for me to find at auto parts store.
Frank Biscardi
04-26-2001 03:52:08
 Re: Re: Oil f0r TO-20 in reply to Duner Wi, 04-25-2001 10:34:40
I doubt I put >30 hours a year on my to-20. Do I still need to change the oil once a year?
Thanks
Frank
Duner Wi
04-26-2001 04:27:01
 Re: Re: Re: Oil f0r TO-20 in reply to Frank Biscardi, 04-26-2001 03:52:08
I would recomend changing once a year. Even if you warm the tractor every time you use. If you used it for 5 minutes a day , every day , then I would say to change more often.
