Tiller size for TO20
Clint Wolske
04-23-2001 23:20:43
I am considering buying a three point rototiller for my TO20. What is the largest size it will handle? I was considering a 5 foot, but I am not sure the TO20 will handle it. Any advise would be appreciated.
Thank, Clint
Wayne Smith
05-14-2001 14:52:43
 Re: Tiller size for TO20 in reply to Clint Wolske, 04-23-2001 23:20:43
Clint, I have the same experience as the others. I really wanted a tiller for my TO-30 but ground speed was too great. I opted for a pair of 14-inch M-F plows and a 6-ft double row disc with "bog-type" disc blades. Works really well in my soil, but, the 14's might be a bit hard to pull in clayey or sticky soils. 12's might be better.
Wayne Smith
05-14-2001 14:51:40
Clint Wolske
05-01-2001 18:16:35
Thanks to all for your help and comments.
Clint
Neal(IN)
04-24-2001 04:23:10
Clint
I have no personal experience with this but from reading other messages on the boards it appears that the 20 along with the 8N are not good tiller tractors. The reason given is that even in first gear they move to fast to let the tiller do its job.
Neal
Brent
04-24-2001 21:53:53
 Re: Re: Tiller size for TO20 in reply to Neal(IN), 04-24-2001 04:23:10
I to was told the ground speed was to fast and then I heard about a kit for the trany to make it a two speed version and work with a tiller. Does anyone know where I can find this kit or were to look for one?
Neal(IN)
04-25-2001 09:48:31
 Re: Re: Re: Tiller size for TO20 in reply to Brent, 04-24-2001 21:53:53
I'm not aware of any accesory transmission made today for these tractors. There are Hupp and Sherman auxilary trans available used but they reduce the PTO speed as well as the tractor speed so not good for a tiller. I have read about a Howard transmission and an Epicyclic transmission that go between the existing trans and the rear end so that the tractor is slower but the PTO speed remains the same. I have added a link below to a page with pictures of the Epicyclic trans.
The Howard was, as I understand it, specifically designed for use with the Howard Rotovator which I suspect is a form of tiller. As you can tell I'm just repeating things I have read. I would like to find one of these myself but I bet they are scarce and expensive.
Neal
