TO-20 Carb Adjustment
Richard
04-23-2001 14:57:01
I have just rebuilt the carberator on my TO-20 and would like to know the drill on adjusting the main needle valve. Does this valve control the mixture at low, mid range or wide open throttle? How many turns open should I set the valve to start with. The tractor starts and runs well at a wide range of settings but I would like to know how to adjust it for the best power output. thanks for any help.
Ray,IN
04-23-2001 18:42:41
 Re: TO-20 Carb Adjustment in reply to Richard, 04-23-2001 14:57:01
Carb.adj. is: the idle air adj. screw is near the top front of carb. at about a 20deg. angle to the right. Open this screw approx. 7/8 turn from shut, warm up engine and fine adj. until idling smoothly. The main power jet screw is on the float bowl in the front. Open the main jet screw approx.1 1/4 turns, when warm adj. the screw to run smoothly under load. Do not shut the screw to less than 1 full turn! This will not allow enough fuel to properly cool the valves, and the result is burned valves. This is from the owners manual.
