TEA-20 steering arm seals
Joe in NY
04-19-2001 15:29:44
Another question on the new TEA. The arm seals are leaking (ain't they all)but this one I might fix. Are there seals readily available? Also I have heard that you can drain the housing install zerks and just grease. Does anyone have any input or experiance with this.
Thanks in advance,
Joe in NY
Cliff
04-19-2001 16:39:44
 Re: TEA-20 steering arm seals in reply to Joe in NY, 04-19-2001 15:29:44
The seals that fit my TO30 perfectly are NATIONAL473423, available at any bearing shop for about $8.00 ea. Use 80/90 gear oil, not grease. Fill to just below arms & oil will distribute ok. Take your time installing seals & re-assembly.
Jim
04-20-2001 16:12:41
 Re: Re: TEA-20 steering arm seals in reply to Cliff, 04-19-2001 16:39:44
I have heard many say they choose Grease over Oil because of the leakage, 1" x 1/4" bushing with a 1/4" zert. Mine needs rebuilt, I put new Stearing shaft bearings in but did not tear into the bottom half. There are two sets of Bushings that need replaced in my Stearing housing, I did call about the price and was told they were..... ..... $35.00 for each bushing..... .scared me, because there are 4. Has anyone rebuilt for less. Massey dealer did not know, but they could possibly come in a set of two for $35.00, book did not say.
Paul in NM
04-21-2001 16:10:16
 Re: Re: Re: TEA-20 steering arm seals in reply to Jim , 04-20-2001 16:12:41
Jim - I once had the same problem. I went to a bearing house and gave them the dimensions I needed. They were able to order the size I needed, except they were too long. I just cut them off with a hack saw and they worked fine.
Outer bushings (2): 1-5/16" x 1-7/16" x 1-13/64"
Inner bushings (2): 1-1/8" x 1-7/16" x 1-1/8"
They were brass, I believe, and very reasonably priced.
Paul
Joe in NY
04-22-2001 17:41:14
 Re: Re: Re: Re: TEA-20 steering arm seals in reply to Paul in NM, 04-21-2001 16:10:16
Thanks for your help men.
Joe
