TO 30 GOVERNOR INSTALLATION
jimmy
04-18-2001 19:12:26
I HAVE A TO 30 WITH NOVI BALL GOVERNOR ,WHICH I AM INSTALLING NEW , BUT I HAVE REASON TO BELIEVE THAT SOME HAS THE LINKAGE WRONG SOMEWHERE ,I NEED SOME PICTURE OR ADVICE ON THE L SHAPED LINKAGE PART WITH A SPRING HOOKED TO IT UP IN FRONT , THE SPRING HOOKS TO THE WATER INLET HOUSING I KNOW ,BUT HOW DOES THE L SHAPED PIECE GO ? OVER OR UNDER THE CONTRL ROD ,I NEED A PICTURE OR DIAGRAM .THIS THING HAS NO GOVEROR RESPONSE AT ALL AND I DIDNT REALLY SEE ANYTHING WRONG WITH THE BALLS ANY IDEAS WILL BE APPRECIATED. JIMMY
Bar N
04-19-2001 13:12:56
 Re: TO 30 GOVERNOR INSTALLATION in reply to jimmy , 04-18-2001 19:12:26
third party image
Hers a pic of Gov. hookup.
Hope this helps
Martin (IN)
Jim
04-20-2001 15:49:48
 Re: Re: TO 30 GOVERNOR INSTALLATION in reply to Bar N, 04-19-2001 13:12:56
Wow Martin, are there more Tractor Pics available?
I could not find them at Photo.com, can you help?
I could not tell by the picture but I am sure the L-shaped bracket goes down on mine, it would hit the gas tank if on top!
Bar N
04-20-2001 18:32:52
 Re: Re: Re: TO 30 GOVERNOR INSTALLATION in reply to Jim , 04-20-2001 15:49:48
Hi Jim,
Do yourself a favor and pick up one of these
manuals.This is where I got the pic. from.Much
better than the FE-2 manual.
