TO20 Tractor
Cindy Lou
05-20-2008 16:42:18
I would appreciate very much some info on how I can determine the value of a T020...runs good
but needs body work (needs painting & one headlight repaired)...I have to purchase something I can handle easier..the TO20 wears me out!!!
It has this info on plate on the "dash" area:
Harry Ferguson Inc - Detroit Michigan SER # TO-58595
ALso..are there any magazines that list info on old tractors and implements?? (Values, rarity etc)
THANK YOU!!!
Bob (Aust)
05-21-2008 15:51:07
 Re: TO20 Tractor in reply to Cindy Lou, 05-20-2008 16:42:18
Cindy.
Gasoline just hit Aus$1.70 per liter (US$6.46 per gallon) in my home town here in Australia.
Forget the tractor - how much do you want for the gasoline in it's tank? :x
Bob in Oz
'53 TEA20
Jeff-oh
05-22-2008 06:25:29
 Re: TO20 Tractor in reply to Bob (Aust), 05-21-2008 15:51:07
Bob thank you for proving my post of last week... "new tractor value question"....
Hills Of TN
05-21-2008 11:56:33
Cindy, in my area: Assuming it runs good and good hydraulics, low end is about 1,500 and high end is about 2,500. Condition of tires and tin would determine where it would fall within the above range. Now if it was a trailer queen, don't know because I have never seen A ferguson like that in my area!
phil(va)
05-20-2008 20:50:09
If tires are decent, hyrdaulics work ok, engine doesn"t smoke, might be worth $1600 - 2200, just a guess. I"m in Virginia. They sell fairly well in this area.
Tony Lawson
05-20-2008 18:07:21
I just purchased one in southern ohio for$1000.00 and put about $300.00 into updated 12volt electrical system, new belt, battery and fluids and it has no lights and the steering wheel cracking up. Compared to most I've seen I think I did real well. Most I've see that run and operate good start around $2500.00
Jeff-oh
05-22-2008 06:01:04
 Re: TO20 Tractor in reply to Tony Lawson, 05-20-2008 18:07:21
Tony where in S. Oh are you? I"m on the East side of Cincinnati in N. Clermont Co.
Tony Lawson
05-22-2008 17:37:12
 Re: TO20 Tractor in reply to Jeff-oh, 05-22-2008 06:01:04
Jeff, I'm actually in Eastview Kentucky. Which is about 20 miles southwest of Elizabethtown Kentucky. I purchased the tractor from a farmer that lives down the road from my father who lives in Buchanan Ohio. Which is on the other side of White Lake outside of Waverly Ohio.
Richard L
05-20-2008 17:17:07
I won't give a value however 1 question they would like to know is where are you located. That could make a difference, also one gentlemen asks if the gas tank is full or empty that would be about $40.00 more if full.ha ha
Cindy Lou
05-20-2008 17:22:55
 Re: TO20 Tractor in reply to Richard L, 05-20-2008 17:17:07
Located in North Carolina...think there is about
3 gallons of gas in it...thats about $12 here!!!
THANK YOU!!
Bob (Aust)
05-20-2008 17:05:53
1951 Ferguson TO20, built in the USA, Continental Z120 engine, 23.9 HP.
No idea on values, sorry. But one of the experts should be along shortly.
Bob in Oz
'53 TEA20
Stephen L Atkins
05-21-2008 17:28:53
 Re: TO20 Tractor in reply to Bob (Aust), 05-20-2008 17:05:53
Cindy,what do you mean,wear you out. Mabe you should get a good seat cushion and check the steering mechenism. We had a TE20 an later a TO30. They never wore me out.
steveormary
