TO-30 distributor
John-30*
05-18-2008 08:38:18
The distributor in my 30 is worn out. Enough play that the points will double their gap when the shaft is pushed. One of the advance springs is gone and not a drop of oil or evidence of any in it. Amazingly it would still run, albeit not well. New distributor time? I see them on this site. Rebuild possible? If so where are parts available? I warned you I would be seeking advice. Hopefully one day I will be able to offer some. Thanks, John
Jerry/MT
05-18-2008 20:46:05
 Re: TO-30 distributor in reply to John-30*, 05-18-2008 08:38:18
I had one that had so much shaft/bushing wear that when I pressed on the shaft radially the points went from closed to 0.030" open. I had a rebuilder in Portland, OR(www.philbingroup.com)rebuild it in 2006 for $100 plus shiping. They remachined the shaft and then fit a bushing to it and checked the breaker plate and the advance mechanism out. I
f you have a real auto electric shop near you, they should be able to rebuild it for you. Oiling the distributor and keeping the distributor oil reservior full is probably one of the most neglected maintenance tasks on the tractor. A rebuilt distributor is about $150 exchange + shipping.
