loader control
frank351
05-18-2008 07:51:23
I have a loader hooked up to the lower port on my 51 to30, I use a ball valve to hold it in place. can I put a return hose on it. it looks like their is a port near the top right side. so that I can use a spool valve to control the loader instead of the draft control and ball valve?
John (UK)
05-18-2008 08:09:25
 Re: loader control in reply to frank351, 05-18-2008 07:51:23
You can use a spool valve to control the loader but you must return the oil through one of the round side plates NOT through the plug on the top right side (or left side) as that is a pressure point and DON'T return it through the gearbox filler plug or you will starve the Pump and overfill the gearbox. You will need to move the Tractor Quadrant lever to the top and leave it there so you will have an oil flow, you will also need to prevent the lower link arms from rising fully as this will shut off the Pump and you will have no pressure. For the return point, Ferguson used to make an adaptor that straddled three of the bolt holes that held the round cover on, the oil was returned through the centre hole and the two outer holes were used to fasten the return adaptor to the tractor.Make sure if you use this idea that the pipe retuning the oil goes at least one inch inside or it will leak down the side of the tractor....John
