Last week I posted a message about sudden overheating problems with my 1950 TO-20. I did all the things folks recommended, such as cleaning the radiator, checking the water pump and thermo, timing, carb mixture, etc.Today I started it up and waited for it to warm up. It noticed that as the engine warmed up there was a lot of movement in the radiator water, but it never warmed up. As the engine temp started to climb very quickly, I turned off the engine before it overheated. The water in the radiator was still just as cool as when I started the engine. When I felt the top hose going from the radiator to the engine, it was very hot just below the thermo, but cool above it. I gave the hose a squeeze below the thermo and suddenly the thermo opened with a vengeance. Very hot water surged from the engine and into the top of the radiator, and cool water in the radiator flowed into the engine through the bottom hose. Needless to say, it was something like a geyser out in Yellowstone, but certainly not Old Faithful! Okay, so the problem appears to be a stuck or malfunctioning thermo, which I installed new about a year ago. Just to make sure, I installed it with the spring coil side toward the engine just as I do with the one in my car. Is that correct? Also, when I pulled it out about a week ago and did the hot water test on the stove, it opened fine right at 80 degrees C. So does anyone have any suggestions other than trying a another thermo? Thanks. John
