Seal-rear axle
sidestep,In
04-16-2001 15:48:39
anyone have a parts book for /or/prt # for rear axle seal To 30-condensed repair manual i have say's there is only an inter seal ,but shows an outer also.call,s for re-packing every 1000 hrs,with a press fit ring to hold bearing in place. thinking of re-packing by use of a grease needle,to keep from splitting the retainer and trying to find that part also. Next thing is to try to locate a dealer with a parts person able th read the book in the area
Ray,IN
04-17-2001 22:53:19
 Re: seal-rear axle in reply to sidestep,In, 04-16-2001 15:48:39
I tried to email you a page from the owner's manual detailing this, but the msg was returned "with fatal errors" in the address. Send me your address and I'll try again.
rod
04-17-2001 03:56:03
There is a product called sure seal which fits over the collar most dealers ford or massey should be able to get them I think they run about 10.00 a set. IF you can't find them locally let me know and I will give you an online source for them.
regards
rod
