What have I got
Jim in AZ.
05-15-2008 15:37:26
A have a Tractor that it seas on the hood Fergeson.
On the block there is a tag on the left side that has this # on it. 118513 then at the nnd 30 or 80. 20
Then on the stering collem it has 17882
I would like to now what moter it is so I can get parts for it to get it running. It has set for 5 years and o boy is it bad. Thankyou all Jim in AZ.
Jeff-oh
05-16-2008 08:02:43
 Re: What have I got in reply to Jim in AZ., 05-15-2008 15:37:26
Jim,
Richard has correctly ID you tractor, where in Az are you. There are some really knowledgeable guys out there near the Prescott area.
Jeff
Jim in AZ.
05-16-2008 08:44:02
 Re: What have I got in reply to Jeff-oh, 05-16-2008 08:02:43
Thanks all I live in golden Valley az outside of Kingman.
Richard L
05-16-2008 05:16:11
Ok Jim you have a 1950 TO 20 Ferguson (not Massey Ferguson) LOL. There are several places to purchase parts for the little grey. If this is your first fergie welcome aboard. This Forum has so much knowledge it is hard to not find the correct answer. Richard
Richard L
05-15-2008 15:49:08
Jim on the steering column on that tag does it say TO or TE and then 17882? Left side of engine below dipstick should be cast numbers Z 120= TO 20 if steering tag says TO. Please post again there is a lot of help on this forum. Richard
Jeff-oh
05-16-2008 08:00:02
 Re: What have I got in reply to Richard L, 05-15-2008 15:49:08
FYI Z 120 does not = TO20.
Both the TO and TE tractors in that serial number range had Cont. Z120 engines. The TEA's have the standard motor.
ID'ing the TE and TO is important even though the engine is the same as the TE's have Lucus Electronics and the TO's have Delco-Remy and they are not interchangeable on the piece part.
Respectfully
Jeff
Richard L
05-17-2008 06:25:59
 Re: What have I got in reply to Jeff-oh, 05-16-2008 08:00:02
Jeff, You are correct and I must admit I didn't even think about the difference even though when they say TE I try to get that straight. Well, I am glad I woke up today I learned something already this morning. Thanks for the correction. Richard
Jim in AZ.
05-15-2008 16:39:00
Sory about that Yes ther is a TO 17882 on the steering colum. And below the dip stick this is the # Z120A600 B14Y 00
There ia a space betwen the 600 and the B14Y also the two 00 are under the 0A6
