TO20 Hydrolic problem
Glenn Kurtz
04-16-2001 15:25:26
I was using my TO20 loader bucket and lifting it up, but when I tried to drop it down from half way up it kept lifting up to the top with no response at all from the control lever. It has a freeman loader Model 11900 . The loader worked fine up to that point. Could it be dirt in a valve? I had to release fluid to get it down and it worked for a while after but did it again.
Ray,IN
04-16-2001 20:50:25
 Re: TO20 Hydrolic problem in reply to Glenn Kurtz, 04-16-2001 15:25:26
Sounds like you know the cause. a small amount of dirt,water,rust etc., will cause the spool to stick. In your case, it's probably in the control valve your tractor uses. Thats my guess.
