Temp range for TO 30
guyeli
05-15-2008 06:05:03
Now that we are getting into the warmer months as well as bushogging season I am curious as to what is considered normal operating temparature as measured in farenheit by the temp guage.I am sensitive to overheating issues,but not sure at what temp operation becomes potentially hazardous to the engine.
gshadel
05-16-2008 07:31:50
 Re: Temp range for TO 30 in reply to guyeli, 05-15-2008 06:05:03
What Phil is stating is the thermostat opening temp. So that means that means the 'stat starts to open at 160, and is full open at 180 degrees. Your TO may go hotter than 180 degrees and still not be "overheating" if it is being worked hard. Assuming you have a stock rad. cap rated for 7 pounds, your coolant temp. can rise to 232 degrees before it starts venting out the cap. If it gets that hot.... it's starting to overheat and you better throttle it back to figure out the problem. Most often the radiator fins are just full of chaff and needs sprayed out with a air hose.
George
guyeli
05-16-2008 10:34:58
 Re: Temp range for TO 30 in reply to gshadel, 05-16-2008 07:31:50
Thanks George,that exactly what I was looking for.
phil(va)
05-15-2008 15:11:35
If you are running a thermostat, and you should be, it should control the temp roughly between 160 and 180, depending on the thermostat.
guyeli
05-15-2008 16:42:09
 Re: Temp range for TO 30 in reply to phil(va), 05-15-2008 15:11:35
Hi Phil,Thanks for your response.Does the 160 - 180 degree range mean that at temps higher than 180 the tractor should be allowed to cool back down or what temp is the max operating temp before risking damage.?
