Hydraulics leak
Jack M
04-15-2001 11:46:57
My fergie TEf-20, will lift the hydraulics up and down, but put a large weight on it, eg. mower, link bow full of stone, and it will slowely KLUNK! it's way down. I'm not sure whether this is a split pipe, or if the control valve has worn, and the oil is leaking past it.
Would appreciate the help!
Jack M
P.S. If nothing works, or it's too expensive, I think a Zane Thang would be in order!
Ray,IN
04-15-2001 19:49:49
 Re: Hydraulics leak in reply to Jack M, 04-15-2001 11:46:57
Remove the right side inspection plate(where the dip stick is), and raise the lift. If there is a leak or blown pipe, you will see oil spraying/running/dripping above the liquid level. The relief valve is below the PTO shaft on the rear of the pump,on my TO30 anyway. They may be purchased from a MF dealer; a Ford valve will work but has a lower setting. Take the old one with you to assure you buy the correct new one. If you don't mind getting greasy, you can remove/install it without draining the oil through the same opening. That's my suggestion.
