T- stat location on my TO-20 where is it.
randyhood
04-30-2008 14:43:08
Well i know the t- stat is not in the upper radiator hose. What do i have to remove to find it. thank you randy. TX
Jeff-oh
05-01-2008 07:28:54
 Re: T- stat location on my TO-20 where is it. in reply to randyhood, 04-30-2008 14:43:08
If not in the hose most likely someone removed it and you are running without one.
But that's where it goes.
gshadel
04-30-2008 17:25:19
yup, should be in the upper hose, there is no other place to put it that it would work. If your cooling system is acting like it'd clogged-up, I guess you could pull the lower hose to see if a non-mechanic tried to install the thermo down there.
George
Richard L
04-30-2008 15:48:39
If it is not in the upper rad hose maybe you do not have one or else some one else installed it in the wrong area. It should be in the upper radiator hose.
