TE 20 Water in hydraulic oil
JackfromVA
04-29-2008 16:58:54
From what I read in this forum and the color of my hydraulic oil, all indications point to water in the system. What is needed to clean up the system and is there a way to keep it from happening in the future?
Thanks,
Jack
Jeff-oh
05-01-2008 07:35:47
 Re: TE 20 Water in hydraulic oil in reply to JackfromVA, 04-29-2008 16:58:54
Follow the steps and you'll have nice clean oil.
Bob (Aust)
04-30-2008 06:51:57
Doc
No. It slips over the top of the existing metal parts.
Don't remove the metal boot as the gear stick retaining pin will probably slide out.
Bob in Oz
AussieDoc
04-30-2008 06:00:16
 Re: TE 20 Water in hydraulic oil in reply to JJ/Ga, 04-29-2008 16:58:54
I assume the rubber boot replaces the metal boot?
Or does it go over the lot?
Bob (Aust)
04-30-2008 00:17:37
Doc
[quote:f3f01eef12]"Was that boot original fitment?"[/quote:f3f01eef12]
Dunno Mate. When my Fergy was born I was still a kid in short pants with more interest in girls, than tractors! :lol:
I discovered the boot at a dealers by accident a decade ago and tried it on my TEA20. The part numbers are:
M-F: 180579M3
Sparex: S.40821
Bareco: B2769
Sparex correctly list the part as suiting the TE20, TEA20, TED20, TEF20, TO20. Bareco incorrectly list it on their web site as fitting "All (Non Italian) Models from MF35 on".
Part 12 in this image is the part you want:
third party image
Part 13 in the image is M-F P/N 1678565M2; Bareco P/N B1540, Sparex P/N S.40822 and listed as "an alternate" by Bareco but I suspect it is for a later M-F tractor, not the TEA20.
Bob in Oz
Bruce(OR)
04-29-2008 21:51:08
One way to keep the water out of the spring involves draping a plastic garbage bag over the rear spring. I did it on a 9N I just sold. worked pretty good. Rained and got the bag wet that would stick to the tractor housing.
Jerry/MT
04-29-2008 21:29:36
Depending on the local humidity, condensation has a big role in adding water to the transhydrauic fluid, as do leakage of precipitation around Control Spring Plunger and the gear shift lever boot. Not much you can do about the humidity except to work the tractor hard weekly to heat up the fluid and vaporize the water. Making sure the geart shift boot fits tightly can help with rai/snow running down into the tranny.
AussieDoc
04-29-2008 18:52:24
 Re: TE 20 Water in hydraulic oil in reply to gshadel, 04-29-2008 16:58:54
Bob,
John (UK)
04-30-2008 05:16:39
 Re: TE 20 Water in hydraulic oil in reply to AussieDoc, 04-29-2008 18:52:24
The rubber boot around the bottom of the gear lever was not an original feature. But as the lever and the cover get worn it will allow water to penetrate and get into the Transmission, fitting the rubber boot will stop all that and then cover up the Draft Control Spring as there is a seal in there that will be worn and it will be difficult to change due to everything being seized up, just cover it up at the tractor end of the Draft Spring and change the seal when you have to remove the Hydraulic Top Cover for some reason, as that will be the only way you may be able to do it now.Don't make the mistake when you look at the oil and it looks "milky" that it isn't cause by air mixed in the oil and not water...John
Bob (Aust)
04-29-2008 18:43:01
Doc. The gear lever boot for the TE/TO20 series is Sparex P/N S.40821 (alternate S.40822)
The MF35 rubber boot also fits the TEA20 gear lever.
Jack. Water can also get into the transmission through the depth control spring at the back of the seat which by virtue of the case shape, forms a nice pool, or via the dip stick. You need to cover the tractor from the transmission back to stop rain getting into the transmission.
Remove the two transmission drain plugs, let it drain for a couple of days and refill with new oil.
Richard L
04-30-2008 11:51:29
 Re: TE 20 Water in hydraulic oil in reply to Bob (Aust), 04-29-2008 18:43:01
Jack, I think Bob hit the wrong number. There are 3 drain plugs just in case you didn't know. Richard
AussieDoc
04-29-2008 18:29:31
 Re: TE 20 Water in hydraulic oil in reply to vtscott, 04-29-2008 16:58:54
Is there a rubber boot available for the Fergy? :shock: I've never seen one but would like to have one.
My gear shift only has a metal cup covering the ball joint on the lever.
Richard L
04-29-2008 17:10:52
Jack look under SEARCH THIS SITE type in "cleaning transmission" search area Ferguson forum. If your gear shifter boot is shot get a new one and if you have to leave it out side take a 5 gallon pail upside down to cover shifter from the rain. Richard
