oil system spring
John in MS
04-23-2008 12:34:11
In the TO20 oil system there is a spring that keeps pressure on the metal cover that surrounds the filter element. What exactly is the purpose of that spring, i.e. why is it necessary to have that downward pressure on the cover? It seems that the filter element would hold it in place.
Thanks.
John
Stan/TX
04-26-2008 09:09:39
 Re: oil system spring in reply to John in MS, 04-23-2008 12:34:11
John,
You raise interesting questions. Because I have my TO-20 apart for other reasons I am able to examine the oil filter system in detail. I have never observed or had to deal with a spring. Yes it is in the parts manual. I, like you, want to know some details. How long is this thing or will any spring that fits and lets the cover tighten down/up work? I have one I think will work, but I would like to know more if possible.
George, your description was very helpful.
Also, upon a closer examination of the parts I notice the piece that delivers oil to the inside of the filter only has one "metered" hole. Both the owner's manual and the service manual for the TO-20 clearly state that there are "two metered holes" - do I need to be concerned about this and drill another hole or just let it go?
Thanks for the info. It helps me make sure this thing is put together the way Ferguson designed it. Amazing how much better it runs when you do that.
Stan
gshadel
04-24-2008 10:58:33
John, if that spring wasn't there, the cover, strainer, and filter would bounce up & down in your crankcase on that drain tube with every rock/pothole you hit. That's not a terrible thing, but everytime the strainer unseats from the handhole cover (the plate on the bottom of the oil pan that you remove to drop all that stuff out on the ground), it is possible for some unfiltered/unstrained oil to pass under the strainer and get sucked-up into your oil pump. Keep in mind these engines were designed to run forever in rough service. Is that $2 spring essential? probably not, the cover isn't going to bounce up high enough to hit your crankshaft. I also don't think you need a "special" Ferguson spring. My recollection of that spring is that it's just a plain 'ol spring. You can probably get a good substitute from a hardware store.
George
John in MS
04-25-2008 09:58:39
 Re: oil system spring in reply to gshadel, 04-24-2008 10:58:33
Thanks, George, that makes perfect sense. I found a near perfect spring at Home Depot, but it might be a little too long. I'll just snip off a piece as necessary.
John
maxwell99
04-24-2008 04:08:34
On my TO-35 I have been changing oil it that thing for years and years and did not know it had a spring in it at one time to force downward pressure on the oil filter.
Guess the spring was throw out with the diry oil many years ago. So my oil was just racing around my filter and not going through the filter for these many years.
Once I learned of the spring and washers, I purchased the parts from Argo, changed filter and now am good to go.
Note: Argo has orginal equipment oil filters for the old tractors less expensive than NAPA, who would have though it!!
Richard L
04-23-2008 12:53:41
Sorry I was under the impression the spring was to put pressure to hold the filter in place. Richard
Richard L
04-23-2008 12:51:21
With what little I have read on it if that spring is not in place the oil does not circulate through the filter. That spring holds the filter in place so the oil has to go through the filter. Richard
