To 30
john
04-11-2001 11:23:41
Looking at my first tractor, TO 30. It has smaller pto shaft. Will using an overrun clutch to larger size cause any problems bush hoggin?
Chuck (CA)
04-11-2001 13:52:25
 Re: to 30 in reply to john, 04-11-2001 11:23:41
Hi john,
You just described my set-up and probably 90% of everybody else on this board. No problem. I suppose you could go out and buy a 1 3/8" pto shaft, but I can't see where that's necessary. By the way, I use a 5' King Kutter and the orc has performed flawlessy. And what a difference it makes. I don't even want to get started about the field fencing that ended up in my radiator before I got the orc.
Chuck (CA)
dennis
04-11-2001 14:41:11
 Re: Re: to 30 in reply to Chuck (CA), 04-11-2001 13:52:25
if you find a problem with the smaller, standard Ferguson, pto shaft, you can get an adapter that slips over the shaft and brings it up to the full size. I got one to drive the pump on my backhoe. Costs about 20 bucks.
