mark from the fort
04-12-2008 05:43:25
Re: scraping backwards in reply to mike-hr, 04-10-2008 14:19:30
I had thought of a couple of other "tips" for ya. When moving snow, do it with your blade at an angle so that it is sliding off of the blade--this way you don't get a HUGE load of snow and eventually stop the movement of the tractor. -like you see snow trucks "shooting" the snow at an angle towards the ditch. BUT, remember to use your "leveling" handle that should be part of your, most likely right side, lift arm. With every angle you set the blade, it will NO longer be parallel with the ground. -which I shoot. I usually set my angle in the barn and adjust the lift arm so the blade rises and touches the cement floor parallel. I very seldomly have to touch the blade setting after this. Usually 1 pass up a drive way (rolling the snow to outside of driveway) THEN turn the tractor around and go the other way back down the drive way and I have cleared snow to both sides. **the reason I do not mess with setting is its sort of a pain to stop tractor, get off, move blade setting, get on,and readjust back to parallel with ground. Over and OVer. A second thing I want to mention is to invest in "sway bars" for your blade. Just incase you are not familiar, these are thin flat bars that will hood to the a) same pin as lift arms on blade and b) other end to a bracket directly under fender mounts. These keep the blade directly behind the tractor with NO side to side movement of the blade. Very important as some attachments have swung too far to one side and have gotten caught up in rear tire tread and pull up tire and ruined fenders, cut tires, bent lift arms. Very inexpensive and very worth the piece of mind as any implement with stabilizer/sway bars is kept under much better control. Lastly, (sorry for the long post)-if your blade has a spring loaded plunger pin that locks the blade at different angles, you can attach a lenght of rope to the handle and from the tractor seat, you can pull rope-back blade against a tree or similar, and change the blade angle without getting off tractor.-AGAIN, you will most likely have to re-set the blade level again with leveling crank. If you haven't fallen asleep by know, I hope these tips make sense. Mark
