Lift Quadrant Friction Disc
GrampaJack
04-07-2008 08:04:12
Could someone please tell me, what is the thickness of the cork friction disk that goes on the lift quadrant on a TO20? Forgot to order one, I can find cork gasket material locally but I�m not sure how thick it should be. Thanks, Jack
GrampaJack
04-08-2008 04:36:04
 Re: Lift Quadrant Friction Disc in reply to GrampaJack, 04-07-2008 08:04:12
Thanks, I found some that is 1/8". That ought to do. Appreciate the information. Jack
Jeff-oh
04-08-2008 06:16:15
 Re: Lift Quadrant Friction Disc in reply to GrampaJack, 04-08-2008 04:36:04
I have use 1/8 cork to make friction disks for the throttle. So I'd agree that it should work for the quadrant contol.
GrampaJack
04-08-2008 06:53:24
 Re: Lift Quadrant Friction Disc in reply to Jeff-oh, 04-08-2008 06:16:15
While we are on the subject, what do you guys use to glue the disk on? I figured contact cement should work. Jack
Jerry/MT
04-08-2008 17:00:10
 Re: Lift Quadrant Friction Disc in reply to GrampaJack, 04-08-2008 06:53:24
Don"t glue it on. It just provides friction between the lever and the backing plate.
GrampaJack
04-09-2008 04:28:44
 Re: Lift Quadrant Friction Disc in reply to Jerry/MT, 04-08-2008 17:00:10
I had to scrape what was left of the old one off so I assumed one side was glued. Thanks for the information. Jack
Jerry/MT
04-09-2008 09:56:52
 Re: Lift Quadrant Friction Disc in reply to GrampaJack, 04-09-2008 04:28:44
it was overtightened to increase the friction and the binder in the gasket probably cuased it to stick. Mine came apart and I was surprised the difference it made when I replced it. The control lever stayed where it was placed.
John (Ohio)
04-07-2008 17:41:37
Grandpajack,
I measured my new disc and it is 0.180" so just a hair under 3/16"
Hope this helps,
John (Ohio)
Jerry/MT
04-07-2008 11:17:49
Just a guess but it seems to me from waht I could remember it like 3/32". I don"t think the thickeness is all that critical because you can adjust the nut to get the correct tension.
