throttle spring
Jim NH
03-31-2008 19:17:02
What does the throttle compensator spring hook too? I found broken spring hanging from throttle
linkage. I have new spring but can figure out where the other end hooks. I have a 1955 TO 35.
jim
Jim NH
04-01-2008 08:59:28
 Re: throttle spring in reply to Jim NH, 03-31-2008 19:17:02
Thank You for the information. I have a parts book. The picutre was not a good one but it looked like it hooked to some kind of screw with a loop on the head. When I get it
running I will probably take you up on how to adjust the govenor. I inherited the tractor 12 years ago. Having retired I now have some time to get it running correctly. Just got the genertor rebuilt from 6v to 12v and am waiting on 12v coil I ordered. Again thank you
Jim
John(UK)
04-01-2008 09:32:17
 Re: throttle spring in reply to Jim NH, 04-01-2008 08:59:28
The screwed rod that I saw was flattened on one end and a hole for the spring drilled into it, but anything with a loop on it for the Spring will do...John
John(UK)
04-01-2008 05:14:13
Further to the reply by Jerry,
On some tractors the spring also attached to a short screwed rod that was in turn attached to the top hose connection from the Thermostat housing. The rod is nothing too technical, it should be long enough so that you can adjust it as required. The rod is necessary so that you don't try to overstretch the spring. If you need the info on adjusting the engine governor, email me....John
Jerry/MT
03-31-2008 21:54:50
It hooks on the "gooseneck" that goes from the cylinder head to the top hose of the radiator.
