Light wing mounts
Hal Hadaller
03-30-2008 19:23:05
My wings that I have for my headlights are bent. The wing part is bent outwards about 1/4" from the sheet metal. Do these bend easily or should I leave well enough alone? They don't look bad this way but one of them is bent more than the other so is noticeable.
Thanks, Hal
Jeff-oh
03-31-2008 07:23:39
 Re: Light wing mounts in reply to Hal Hadaller, 03-30-2008 19:23:05
Do not cold bend them they will crack.
These are cast aluminum. They do not like to be cold worked.
But there is a way...
Give the wife $20 to $50 to go spend at her favorite store. Now while she's out of the house, put them in the stove and heat it up to 500 degrees. Let them get to temp (about 20 min) Then with heavy gloves pull them out and gently bend them to the right position.
When hot they bend more easily and are less likely to crack or break.
Jeff
Andy Moncman
03-31-2008 10:09:03
 Re: Light wing mounts in reply to Jeff-oh, 03-31-2008 07:23:39
Jeff,
$20 to $50 you wouldn't even have her oven up to temperature before she would have that spent. Take the fifty to the used appliance store or goodwill and buy yourself a shop stove, then you can heat parts and your lunch and never hear how you messed up her kitchen again.
