Thanks John and the hole......................
RonW
03-30-2008 17:18:10
above the cam bearing is definately clogged hard. That is why I ran the outside line. It is quite small, but I do not remember what size. The rockers were running bone dry before that. The old tractor is very worn, I;m sure to include the guides. What is the proper procedure for me run the proper amount of oil to the rocker shaft? Thanks again, RonWW
John(UK)
03-31-2008 07:27:53
 Re: Thanks John and the hole...................... in reply to RonW, 03-30-2008 17:18:10
Apart from removing the Head and clearing out the gallery back to the Camshaft...and you may have to remove that to complete the work, what you have done is fine for now, just find some way of restricting the flow to the Rocker shaft so that it will be more like it was originally and then you shouldn't have the problem of over lubrication, just squeezing the pipe may do it, (very crude but if it works) or if there is room in any of the pipe fittings that you could insert a washer with a small hole that will limit the flow.Have you checked that the Rocker shaft is clear right the way through and that all the other rockers have the lube hole clear so the oil will pass through.The holes that lube the rockers in the Rocker Shaft and in the rockers themselves are very small so they will need to be checked just to make sure they are clear.If they have been running dry like you say then it is highly likely that they will be blocked...John
RonW
03-31-2008 07:33:18
 Re: Thanks John and the hole...................... in reply to John(UK), 03-31-2008 07:27:53
Thanks John. I will disassemble the rockers and clean them. Will also find a way to restrict the flow to the top. As always, I appreciate your help. RonW
John(UK)
03-31-2008 07:59:08
 Re: Thanks John and the hole...................... in reply to RonW, 03-31-2008 07:33:18
Anytime Ron, anytime....John
