OVERHEATING TE20
Ron Jonseck
04-04-2001 20:02:52
Idling and running part throttle without a load it doesent heat up,but as soon as theres a load or I open throttle up the engine starts spraying antifreeze/steam out the over flow,the guy I got it off just put a new waterpump on it,the guy before him supposible put a new/rebuilt radiator on the tractor(maybe needs flushing?),I put a new head gasket on it,why is this thing overheating?I hope someone can help...thanks!
Tex Ferguson
04-07-2001 05:13:20
 Re: OVERHEATING TE20 in reply to Ron Jonseck, 04-04-2001 20:02:52
Well, Ron, these guys have given you good advice. Jim's comment reminded me of a V-8 Ford car I had that would overheat when the A/C was switched on. Turned out it had NO thermostat. Apparently if the coolant circulates through the radiator too quickly, it doesn't cool down, as Jim said. Try a new thermostat. Good luck! Tex
Jim
04-05-2001 17:33:29
Sounds like the New/Rebuilt radiator might need rodded out. I had a problem like this before the more water I tried to circulate thru it (with your increased speed) the hotter it would get. Sounds as though you are not 100% sure of the radiator that was installed two owners ago. That was my first thoughts!! GOOD LUCK.
dennis
04-05-2001 14:36:29
check your timing. That can make it overheat fast.
Ray,IN
04-04-2001 21:45:14
I'd first remove the rad. cap and look for bubbles in the water. This could indicate a blown head gasket (compression leaking into a water passage).If no bubbles, remove the thermostat from the top hose, and check the bottom hose for spongeness/softness. The suction from the pump can collapse a bad hose shutting off the flow. Use air or water pressure to flush the rad. fins from the engine side to remove the trash. Insure the fan belt is adjusted and it's not worn slick and hard, if it is, a little belt dressing(more is not better) will partally renew it. Thats my ideas.
