TEA 20 clutch problem
Max Culkin
03-17-2008 03:40:39
When tractor is first started you can not dis engage the clutch, After 5 mins drivng, pushing clutch in and out the clutch acts normally. Any suggestions ?
ben mc
03-23-2008 01:05:26
 Re: TEA 20 clutch problem in reply to Max Culkin, 03-17-2008 03:40:39
there is a tea at vintage machenry club out in the back shed used as a work horse but poor little horse dose not work ofter but stick a good battery and some gas and she will go runs well but cluch will stick a bit so i just let it warm up for a sec then in tob gear once down the drive its ok good point is clutch will stop tractor but 3 point still works crazy
Toora Stephen
03-17-2008 14:40:32
Um... is a sticking clutch also likely to slip?
- TS
Fred Martin
03-17-2008 13:50:45
I've only had one oil soaked clutch slip on me and it was along the highway in Arizona pulled over in the sand. Even two friends pushing didn't help. But, putting it in low gear and floorboarding it in two gears and letting it smoke did. Drove it on to Rhode Island with no further problems. Sometimes you just gotta show it who's boss. I had already had a rear seal installed, I remember the mechanic telling me that the seal cost him fifty cents and he had to charge me twenty dollars to install it. 1950 Ford in 1960....$199.00 + $20.50. You'd spend that much from California to Rhode Island today if someone gave you a free ride. ohfred
John (UK)
03-17-2008 08:00:29
It can be the Clutch Driven plate stuck to the flywheel, this is usually caused by oil on the plate which means the Rear Main oil seal on the engine crankshaft is leaking and needs changing OR the Clutch drive plate is sticking on the splines on the drive shaft into the transmission and it won't be able to slide easily. Either way the engine will need to come out to rectify the problems. Make sure that the free play in the clutch pedal is correct, there should be a gap of 3/8" under the footrest when the pedal is pressed just enough to take up the free play. If you need the information to do this work, just email me and I will send it out to you.If you write please explain again what your problem is so I don't have to search for it.TY..John [email protected]
phil(va)
03-17-2008 07:18:19
Yes, a sticking clutch can be a big problem. One day it may stick and not disengage at all and you will have to split the tractor and replace it. You may have gotten moisture in there and it is rusted somewhat and sticks. A temporary fix is to block the pedal down at night. This is what many people do when they store their tractors over the winter, etc., to keep it from sticking the following spring. You can put a plow on the tractor and when it sticks, drop the plow into the ground in high gear and this often unsticks it quicker than just driving around.
