TO - 30 Ignition Switch
guyeli
03-12-2008 17:18:00
Just bought a new ignition switch,but don't quite understand the click positions.I know one is to start the tractor and the next is for the headlights,but what is the purpose of the last click position ??
Stan/TX
03-15-2008 08:45:52
 Re: TO - 30 Ignition Switch in reply to guyeli, 03-12-2008 17:18:00
My TO-20 has a TO-30 type switch. It is wired vertical - off, one direction ignition + lights, the other direction ignition only.
craigreavley
03-13-2008 12:21:16
I have the exact same switch, and I do not know what the last position is for. The 4th position shuts the tractor and the lights off. I have no clue why they are that way It goes OFF----ON----ON+Lights-----????? ??
John (UK)
03-13-2008 11:41:11
If it is the same as the original one, then it is a Jerry says, you have a position on the switch so that you can have the side-lights on without the ignition being switched on, when you have to park it somewhere....John
Jerry/MT
03-12-2008 18:42:53
I believe the positions are ignition, ignition + lights, and then lights only, not necessarily in that order. I believe I saw a decal once where lights only was to the left, off was key vertical, to the right was ignitin, then ignition + lights. Don"t hold me to it though.
