Steering arms
teadave
04-02-2001 19:29:28
while fartin' around my tea20 tonight, i noticed that one of the arms coming out of my steering box can move in and out 1/2". is this a big fix, or an easy one. just want to know before i tear into it.
teadave
BOB MARSHALL
04-04-2001 20:16:58
 Re: steering arms in reply to teadave, 04-02-2001 19:29:28
had this condition on my to20 i removed entire steering assembly and found clamps on the splind shaft inside were loose . tightened clamps ,problem solved. hope this helps
Neal(IN)
04-03-2001 05:21:47
Dave
I don't have my manual handy so I can't verify that the box on the TEA is like my TO but here goes any way.
If you look just above the steering arms there should be a big nut and screw on both sides of the box. These control the mesh of the gears attached to steering arms and the gear on the steering shaft.
Loosen the nut and tighten the screw to reduce the play on each side. Do this slowly checking the steering through its full range with each adjustment. The gears are typically worn more in the center so if you set them with the wheels straight ahead the steering will bind when turned. You probably will not be able to get as much of the slop out as you would like when centered.
Neal
