Z-129
GARY
04-02-2001 17:39:54
I NEED TO KNOW THE VALVE SPRING HEIGHT
ON A CONT. Z-129 WHEN VALVES ARE CLOSED.
Tex Ferguson
04-10-2001 18:35:46
 Re: Z-129 in reply to GARY, 04-02-2001 17:39:54
Gary, I never thought about this before, but as the surfaces of the valve seats and valve shoulders wear each other down, the stem should gradually sitck up higher above the head. The greater the spring height, the more wear on the valves and seats. In my (limited) experience adjusting valve clearance, mostly on old VW beetles, most times the clearance was greater than spec, which implies that some other wear factor is operating at a faster rate than the valve wear. Who has the answer to this riddle?
Tex
Duner Wi
04-06-2001 09:51:30
Valve spring installed height according to I T manual # FE 2 is 1 45/64 inch.
Jim
04-04-2001 19:42:46
Valve Spring Height? You mean length? or are you looking for a gap setting? I am guessing a TO-30 has a Z-129 if so I looked up the clearance in "Research and Info" in left hand colum from this page, the clearance is .014H, not sure what the H is. Hope this helps.
Chuck (CA)
04-03-2001 16:25:57
Hi Gary,
Well, my IT Manual doesn't seem to list it, but I happen to have the rocker arms off, and by measuring with a tape measure, it seems to be 1 5/8". Hope this helps.
Chuck (CA)
