TO-20 engine number
John in MS
03-11-2008 17:35:56
From the information on the plate on the steering panel I have a 1950 TO-20. The other day I noticed that the number on the left side of the engine was "Z 12" and then a few spaces to the right it had "A 600". I thought the engine number should be "Z 120" and was curious why it has only "Z 12." Any thoughts?
Thanks.
John
Dan S (NY)
03-12-2008 09:12:34
 Re: TO-20 engine number in reply to John in MS, 03-11-2008 17:35:56
third party image
You may have a replacement block. They used Z129 blocks to replace Z120 blocks when you could still buy brand new replacements. The 9 was ground down on the few I have seen. If this is the case, you should see a boss on the right side of the engine where the external oil filter would have gone on a TO30.
John in MS
03-12-2008 13:13:27
 Re: TO-20 engine number in reply to Dan S (NY), 03-12-2008 09:12:34
It looks like whatever should have been in the 0 position was ground off in the casting, so your idea that this is a replacement TO-30 block might be the answer. I'll check to see if that boss is there. The more I work on this tractor, the more intrigued I am with its apparently sordid history. Although it purrs nicely, I wish it could whisper its secrets to me.
John
Richard L
03-11-2008 19:19:47
My only thought may be it either has been worn off or posssibly it was not a deep cast on the 0. If it is dirty in that area try scrubbing some of the dirt off and double check if there is a faint 0. It should show Z 120. Good luck.
