Tractor won't start...
Jeff-oh
03-11-2008 09:48:51
How many times has this happened to you?
Last Friday I get home from work. We have 4" of snow already down out of a predicted 12" to 15". I fire up the old TE and clear off the drive.
Wake up Saturday Morning and She'll barely turn over... Okay the battery is run down some. I take it in and put it on the charger.
Couple hours later I go back out, hook the battery up and Er-er-er-er-er-er Turing over great but will not catch.
Check the throttle, check the choke... Er-er-er-er-er-er.
Tap on the carb because I've had a stick needle valve... Er-Er-er-er-er.
Pull the drain plug and fuel come pouring out... Er-Er-er-er-er
Go dig around for starting fluid... Pull a plug spray in some starting fluid, re attach plug.... Er-er-er-er-er.
Repeat the above process... Er-er-er-er-er.
Scratch head, curse a little, move the throttle back and fourth as if that will magicaly fix my problem....
Then....
What's that....
Ya dumb idiot... ya forgot to put the key in and turn on the ignition circuit. Va-room....
Ran like a charm as I pushed off the next 10" of snow that had fallen.
I confess I have failed to stand up to my own expectations for tractor operation. And now I must work to regain the confedence you all have placed in me.
Jeff
Irv ( Ia)
03-23-2008 16:37:59
 Re: Tractor won't start... in reply to Jeff-oh, 03-11-2008 09:48:51
Not a tractor story, but humorous. My brother had a neighbor, "Bob", who was one of a kind. He had a tractor dealership with his brother for many years, but his mechanical knowledge was zero. His wife fixed everything and kept him out of trouble. One day he comes out to start his car and it won't go. After repeated attempts to get it to run, he goes back in the house and gets his wifes set of keys to see if that would help!!
It didn't!
Another time he backed out of the driveway into the street and attempts to go forward. He guns the motor, it acts like it wants to go , but no go. So he backs up again, now almost to the curb and tries to go forward again. No go! One more time, and now he's clear up in the neighbors yard across the street. Once again, no go. He leaves the car in the yard, goes to the house to get "Dorothy", and she comes out, takes one look, pulls the emergency brake off, and "Bobs" on his way. LOL I think there's a little Bob in all of us.
Irv*
Bob (Aust)
03-13-2008 19:20:27
On a number of occasions before I installed electronic ignition, I have checked, cleaned or adjusted the distributor points, replaced the cap and tried to start the engine - without the distributor rotor!
Don't feel embarassed - there's those that have and those that will! :lol:
motorv8N
03-13-2008 18:29:51
I've got the opposite disease. I forget to close the fuel shut-off. Scenario usually goes something like this:
Have fun clearing snow
Park tractor
Make a cup of tea
Drink tea while gazing out admiring the little beast
Notice pool of liquid under tractor
Open door to go investigate
Smell gas
Roll eyes
Curse
Shut off gas
Empty overflowing carb
Did about ten neighbour's drives last storm and got home from work the next day to a nice pile of baked goods that magically appeared on the doorstep.
This tractor is making me fat.
gshadel
03-12-2008 07:44:19
Jeff, can't tell you how many times I've forgotten to open the gas shutoff, only to have the tractor stall about 10 feet from the garage. First time I did that I somehow convinced myself I had an ignition problem and spent ~1/2 hour going thru checking my spark, connections,etc.... before finally figuring out my problem.
I got a good 18" snow up here in Morrow County myself with that storm. I waited until Sat. to fire-up my Fergy. I think I pushed snow for about 2.5 hours, cleared my drive, neighbors drive, a path back to the barn, and was looking for something else to plow... finally decided to quit for the day.
George
Jeff-oh
03-12-2008 06:39:41
BTW:.... The "I confess I have failed..." was a poor take off of the speach made by the Gov. of NY that same day for his confession to his short-commings.
Bill Brox
03-11-2008 16:25:50
Jeff, look at the bright side of it, at least you were out with the tractor when it did not start.
:-) Who hasn't done silly things with tractors or cars, or whatever.
LOL... I have a couple of funny stories about a man I know. He manage to do things no other humans can ever come up with. Once his headlamps on his car was full of ice, and he took a hammer in the garage, and was a little too hard and broke the glass. But, the worst is that he went over to the other headlamp and tried to be more gentle and broke that glass too.
Same fellow got stuck with a tractor in mud, and took a 4x4 and put it in front of the rear wheels and tied it to the tires, and did not think about the fact that he could only drive until the 4x4 was in the rear of the wheels. He continued driving, and had to jump off the tractor to save his life. He did not save the fenders, seat and steering wheel.
Another fellow, extremely absent minded destroyed the block heater inlet on the car, never remembered to remove the cord. Drove out of the garage, and heater inlet flew away. Then to the garage to have them put on a new one, and the same thing happened again and again. Finaly he came up with the idea to put a spare tire on the hood, so he would have to walk to the front of the car to remove it, in hope that he also remembered the cord. No chance... the next morning he slammed the door on the car and starting. Then he discovered the spare tire, and CURSED the kids big time for putting a spare tire on the hood. Went out, removed it, back in the car... and you can guess what happened to the block heater inlet... again.
So, don't feel upset or ashamed for small things like that. We are all humans. Once we are born, we start doing funny things.
When things get a little hectic, I manage to do my own silly things, like holding my hand under the water tap, and hitting the handcleaner dispenser with the other hand,... shouldn't I know that the hand cleaner hit the floor instead of my hand under the watertap.
And by all means, feel free to laugh yourself silly over me.
Bill
Fred Martin
03-11-2008 13:50:27
Jeff...I got a solution for you (and Me)...get a small light to mount under the dash that comes on when you turn the ignition switch on. I've done that too. Or get a volt meter to take the place of the ammeter...It'll register when the key is turned on. ohfred
Mark from the fort
03-11-2008 13:00:01
I called my first TO 35 some pretty choice words after my father and I spent the better part of a day (I was 12 at the time) rebuilding the carb, checking her over, etc. Dad was a great teacher. I ran her for 2 hours straight that night.
Boy was I mad when I couldnt get her started to take back to the pond fishing. (At 4:00a.m.)
Dad didn't tell me about the High/Low shifter.
(and yes, I KNOW, he left that out on purpose)
Still have the tractor, but would give her away in second to have Dad back.
Jerry/MT
03-11-2008 11:49:47
I"m glad to hear that you"re human, Jeff! I have had the key in place and forgot to turn it on and after a I crank it and it doesn"t start, I realize that I haven"t closed the ignition circuit! The dead tip off is that it other wise starts in less than a turn. The common thread here is that we both work (past tense for me) in the field of aircraft propulsion. Do you think there"s any significance to that?
Balatonm
03-11-2008 10:25:41
LOL, Never had that problum because I don't take the key out, it always stays in the tractor. The only problums Irun into are when I forget to turn the fuel on.
Jeff-oh
03-11-2008 14:26:49
 Re: Tractor won't start... in reply to Balatonm, 03-11-2008 10:25:41
I've done that too.
I have forgotten to pull the choke.
I have forgotten to advance the throttle a little.
Although I will say I have enough expierence with this tractor to know it should run fine and nice.
Last summer, I went to our local tractor show and was running a little late for the parade. After about 5 attempts at pulling it with a John Deere (Oh the humiliation!!!) and poping the clutch I sheepishly turned the key to the on position and she started right up.
Richard L
03-11-2008 19:29:04
 Re: Tractor won't start... in reply to Jeff-oh, 03-11-2008 14:26:49
Jeff don't give up if it weren't for things like have been related here this would have been a wasted forum today. I am sure there are some sitting in the back ground saying to themselves I am not going to say what I did back in 19?? LOL Richard
Jeff-oh
03-12-2008 06:34:57
 Re: Tractor won't start... in reply to Richard L, 03-11-2008 19:29:04
Ya know it. Life is too serious not to laugh at yourself. Gotta have fun.
