TO 20 steering shaft bearing
randy hood
03-07-2008 18:59:00
I have been having trouble with the steering shaft on my tractor wanting to rotate upward, when turning. I took the upper housing off and the shaft out, and there i think was my problem. It looks like there used to be a bearing, about in the middle of the shaft, is this right?. are there two bearings. one in the top, and one in the bottom. and is there a timken cone on the bottom as well. need some input thank you randy,from TX.
Bob (Aust)
03-09-2008 00:27:14
 Re: bob what manual is this out of. in reply to randy hood, 03-07-2008 18:59:00
The best manual is probably the original factory manual, which I have.
However, I personally find the Gregory's manual the easiest to use for most tasks.
third party image
Around Aus$40 on Ebay.
Bob in Oz
P.S. Whilst the cover says "TE20" it does not include the Continental engine, only the Standard engine.
Bob (Aust)
03-08-2008 05:56:41
 Re: TO 20 steering shaft bearing in reply to randy hood, 03-07-2008 18:59:00
Randy
Identical bearings top and bottom, cup, cone and cage. Nothing in the middle.
third party image
Bob in Oz
randy hood
03-08-2008 10:11:28
 bob what manual is this out of. in reply to Bob (Aust), 03-08-2008 05:56:41
Bob can you tell me what manual that you use. I don't have such a detailed manual. I would like to get one like that. thanks randy
Bruce(OR)
03-07-2008 22:49:29
If memory serves me, there was a bearing on Fleabay last nite or two for the steering shaft less than $5.00 Try ferguson tractor or to20 and it might come up.
phil(va)
03-07-2008 19:57:40
Yes, two bearings, one top and one bottom.
Bill Brox
03-11-2008 01:24:27
 Re: TO 20 steering shaft bearing in reply to phil(va), 03-07-2008 19:57:40
Does anyone know if these bearings are the same on the TE 20 series and the TO series ?
Bill
Hills Of TN
03-11-2008 05:13:20
 Re: TO 20 steering shaft bearing in reply to Bill Brox, 03-11-2008 01:24:27
Yes, according to the parts manual.
