INJECTOR PUMP
TOMMY SIMS
03-06-2008 08:33:05
I HAVE A MF35 PERKINS DIESEL THE INJECTOR PUMP IS LEAKING AROUND, THE SMSLL INSPECTION PLATE ON THESIDE OF PUMP I NEED A USED GOOD PUMP. OR AREPAIR KIT THANKS TS SERI#SNM247933 ENGINE 37111-280M MODEL 189459MI
John (UK)
03-08-2008 10:02:21
 Re: INJECTOR PUMP in reply to TOMMY SIMS, 03-06-2008 08:33:05
If it is the plate held on with two small screws and possibly locked with wire. Just remove the plate and make a gasket for it, using the plate as a template. You will need to bleed the air from the system when you refit the plate through the two small bleed screws on the side of the Pump Body, slacken them off one at a time and press the fuel feed pump priming lever slowly until all the air is out of the Pump, you will hear it stop spitting when there is no air. If you pump it to fast it will keep sounding as though there is air in it due to the fuel pressure you are creating....John
Jerry/MT
03-06-2008 11:37:21
You"ll have a better chance of getting a quick reply if you post this on the Massey Ferguson Forum. This is a Harry Ferguson Forum. Good Luck!
