Oil loss
Francis
04-01-2001 08:38:30
I have a 51 TEA 20, bought new by my father.
I have used it to plow snow all winter, but when I park it back in the garage, a puddle
of oil shows up on the floor under the clutch
area??? The engine oil does need to be added
a little over the winter.Using 10W30 oil???
Joe in NY
04-01-2001 09:50:39
 Re: oil loss in reply to Francis, 04-01-2001 08:38:30
Francis, How much of a puddle? Can you tell what type of oil. Motor or gear oil? On the bottom of the bell housing is a weep hole with a cotter pin in it. That is were the oil will come from if the seals are leaking from the transmission or rear engine.
Also the steering box seals seem to always leak. Could it be running down the side from there? Check that the level in the transmission isnt to high. But if it ain't a huge puddle and levels are OK, I just throw another piece of cardboard on the floor. Good luck hope you find the problem.
Joe
