TO20 Drawbar
Robert Hampton
03-04-2008 03:02:46
Has anyone got a picture, or can you explain how the drawbar kits mount on my TO20? Thanks for all your help. Robert
Harrison in Dallas
03-04-2008 09:49:24
 Re: TO20 Drawbar in reply to Robert Hampton, 03-04-2008 03:02:46
What size bolts are required? I"ve read 5/8" 11tpi on this site, but that is way too big for the holes on my 51 TO 20.
Thanks in advance.
Jeff-oh
03-04-2008 06:20:11
third party image
The four bolts that hold the front bracket on are obvious when you crawl under the tractor. The Aft Bracket (with the diamond cut-out for the PTO mounts using the PTO retainer bolts.
Not too hard.
Richard L
03-04-2008 05:01:12
Robert 4 bolts under rear end holds front of drawbar bracket then back is bolted around PTO or pinned to Rocker link under seat. To see pictures of different styles-left column this site Research & Info click on Search this Site-then where it says Search For- type in to 20 drawbar. in Search Area click on arrow and scroll down to Ferguson then go up and click on search. then go to bottom to # 23 click on 23 and scroll down there are 6 different pictures of different styles. Pick what looks good to you. Also this site sells drawbars if you haven't got one. Left column top Market Place click on "Tractor Parts" then do what it says to get to drawbars. Good luck
