Serial number problem
Don
03-31-2001 08:41:26
When I bought my tractor I was told it was a to-30, problem is the number off of the motor serial plate doesn't add up. The number is 344591 and none of the lists seem to go that high, their only five digits. Is there a sure fire way to tell exactly what I've got. From other photo's it could be a to-20 or a to-30.
Joe Margol
04-11-2001 14:02:46
 Re: serial number problem in reply to Don, 03-31-2001 08:41:26
Don You have a TO-30. My dad has had his since it was new and it has a Serial Number of 321873. I did some research once and found out it is a 1952. Which dad confirms since he bought it then.
Joe
Neal(IN)
04-02-2001 04:55:52
Don
The serial number you need is located on a plate just under the steering wheel between it and the dash. You should be able to see it when sitting in the seat.
Neal
Jim
03-31-2001 09:04:07
You can look up your serial numbers under research and info in left hand column from this page. One sure fire way to tell TO-30 from TO-20 is the Oil Filter, 30 is on side of Block, 20 is in bottom of Oil pan unless it has been altered.
