TO-35 Old Filter Question
Fred T. Hart Jr
03-02-2008 17:47:52
Question: Is a TO-35 gas model zi34 cannister oil filter suspose to have a spring inside cannister to press filter aganist motor block?
saw this post on another Ferguson forum
They were dicussing a 135 diesel tractor:
If it still has the ORIGINAL cannister type filter, make certain the filter element is "spring loaded". There's a spring and washer that goes below the filter element. The bolt that holds everything in place passes through that spring/washer. It's very common to find these tractors where that spring is missing. If so, the filter doesn't seal to the block and oil will literally bypass the filter.
My old TO-35 has a cannister oil filter, but I have never seen a spring inside cannister, I always buy Wix oil filters for the tractor.
Just thought I would ask if mine is missing. I can see how oil could just circulate inside canister without going through oil filter if there is no pressure to hold filter aganist tractor block.
Sincerely,
Bob (Aust)
03-05-2008 14:02:11
 Re: TO-35 Old Filter Question in reply to Fred T. Hart Jr., 03-02-2008 17:47:52
I made inquiries in the UK for a spin on kit for the Triumph sports car. If I get any indication a kit is available and will fit the TEA20, will post here.
Amazing what one can find if one searches. I found a new oil filter spin on modification kit, PLUS oil cooler and hoses for my 6 cylinder E Type (XKE) Jaguar for only UK�240.00. Since found out it is the same as fitted to the Jaguar sedan and think I can get the complete kit, used, for less than $100!
Just takes a bit of searching. Google and EBay are very useful!
Bob in Oz
Bob (Aust)
03-04-2008 04:43:46
Phil. I am aware Sparex have spin on oil filter kits for Continental engines but I can't find a similar kit for the Standard engine in my TEA20.
Any idea where I may be able to get one?
Bob in Oz
Just had a brain wave - I'll check if a spin on oil filter kit is available for the Triumph TR2, TR3, TR3A or TR4 sports car.
Same engine as my Ferguson tractor!! :lol:
phil(va)
03-05-2008 12:52:06
 Re: TO-35 Old Filter Question in reply to Bob (Aust), 03-04-2008 04:43:46
Hey Bob, I don't know about a kit for Standard engine, but sounds like you have a good idea to look at Triumphs. I do know the Sparex kit says it works for TO-30s but it does not. It works for the TO-35 and F-40, however. In other words it works for the Z134 engine.
phil(va)
03-04-2008 04:35:39
Sparex has a kit to convert to a spin on filter, just FYI.
Fred T. Hart Jr.
03-03-2008 20:31:38
Thanks guys for your replys,
I will take the part number and get one.
Thanks again for your help.
Bob (Aust)
03-02-2008 20:57:40
If the TO-35 oil filter looks like this oil filter..... ....
third party image
..... on my Ferguson TEA20, yes, there should be a spring and plate in the bottom of the filter can.
No spring, no tension to hold the filter cartridge against the mounting, the oil will by-pass the filer thus no oil filtering!
Bob in Oz
FergieFlyer
03-03-2008 11:38:54
third party image
Fred - Yes, there is supposed to be a spring inside the canister. I"ll include a scan from the parts book. Item #21. P/N is 1 750 585 M1. Hope this helps.
Fred T. Hart Jr.
03-05-2008 17:52:44
 Re: TO-35 Old Filter Question in reply to FergieFlyer, 03-03-2008 11:38:54
Ordered oil filter canister spring today at Ferguson dealer. Parts man said the washers had been discontinued, I can buy them when I change oil and install spring. Will have bolt out at that time.
Bought a NAPA Gold oil filter and it did not include the two small rubber seals that go around the bolt.
