TO-20 Exhaust pipe clamp
Dteve (DE)
02-29-2008 17:02:21
Just finished making the three clamps to hang a muffler and tailpipe on my TO-20. Now, as I tighten up the cast metal clamp which holds the exhaust pipe flange to the exhaust manifold flange, its not getting tight. The clamp is made in some far away country, and may or may not be proper, even though its sold as "correct:. So, how tight a fit should this be to keep from having the exhaust leaking out at the manifold to exhaust pipe joint? Are there "good" and "no good" versions of the clamp? Where do I get a good one? Should I be using some exotic material to help seal the joint? This should be easy, but almost nothing ever is.
Steve in Delaware.
ford-s
03-01-2008 06:59:02
 Re: TO-20 Exhaust pipe clamp in reply to Dteve (DE), 02-29-2008 17:02:21
try tapping on the clamp as you tighten it.I have a to-20,and had the same problem until I tapped it,it helps to seat the connection properly.cw
Gene Stevens
02-29-2008 19:14:47
Try turning the clamp over. You may have it on upside down. Gene
Richard L
02-29-2008 18:14:47
check left column-- research and info--search this site then type in something about exhaust it seems as I remember several threads about this subject. I believe one person said he bought a TO 35 pipe and it fit really well. Also remember seeing some one took a aluminum soda can and cut it so it would fit around the two pipes and clamp fit better. I think that clamp has a right side up. Good luck
Dan S (NY)
03-01-2008 06:07:00
 Re: TO-20 Exhaust pipe clamp in reply to Richard L, 02-29-2008 18:14:47
Richard, you can only get a TO35 pipe to fit if you have installed the new aftermarket (TO35 style) manifold. I had to put a new manifold on my TO20 a couple years ago and buoght the 35 pipe to go with it. Works great!
Dan
Richard L
03-01-2008 16:33:52
 Re: TO-20 Exhaust pipe clamp in reply to Dan S (NY), 03-01-2008 06:07:00
Dan, thanks for the info. I thought I read something just didn't put it all together. Appreciate the follow up. Richard
Jackson Knight
02-29-2008 17:19:23
I had the same problem with my to30 I found one at tractor supply that worked much better.
