Transmission/Hydraulic Fluid
Michael William
03-30-2001 11:40:13
I have seen several posts concerning the proper lubricant to use in the transmission/hydraulic system of the TO30. I'm still a little unclear. I
have heard to use 80/90 wt. oil (depending on temperature), and I have also heard to use straight mineral oil. Are these one and the same? If not, what should I use--80/90 wt. oil or mineral oil? I plan on changing mine soon and want to make sure I do the right thing. I really appreciate your help.
Michael Williams
New owner of a TO30!
Hal
03-31-2001 19:56:07
 Re: Transmission/Hydraulic Fluid in reply to Michael Williams, 03-30-2001 11:40:13
If you have Kendall oil in you area they have a product called Kentran 80 which is mineral and good for these tractors.
Brian
03-31-2001 18:40:13
Michael,
Make sure you don't use 80/90 hypoid gear lube since it contains heavy metals such as lithium which can cause acids to form and damage your hydrualic pump over time. Most farm stores carry Ford lube for N series ford tractor this will work if you don't have an MF dealer in your area.
Good luck
Frank Biscardi
04-01-2001 17:21:03
 Re: Re: Transmission/Hydraulic Fluid in reply to Brian, 03-31-2001 18:40:13
Re comment on lithium. Is it ok to use litium based grease in these old tractors?
Frank
marlowe
04-02-2001 20:46:21
 Re: Re: Re: Transmission/Hydraulic Fluid in reply to Frank Biscardi, 04-01-2001 17:21:03
FRANK NO NO NO also NO
marlowe
03-30-2001 13:09:50
massey m1103 is all i use my to-20 is a 1949 is used evey day to feed 900lb round bales bought new in 49 ran a 80 acre farm most of its life never missed a day that i recall an the book calls for mineral oil 90wt which M1103 is. just going by what hase worked for and the book asked for. the cost no more then other oil. just that you need a good massey dealer that will get for you.p.s. just my opinion
Ray,In
03-30-2001 22:17:23
 Re: Re: Transmission/Hydraulic Fluid in reply to marlowe, 03-30-2001 13:09:50
Thats right. 80/90W straight mineral oil. Sold by different names, ask the seller for specifics like Marlowe said.
marlowe
03-31-2001 08:16:31
 Re: Re: Re: Transmission/Hydraulic Fluid in reply to Ray,In, 03-30-2001 22:17:23
thanks ray for the support! this seems like a touchy subject with this oil thing
marlowe
03-31-2001 08:16:20
Michael Williams
04-01-2001 06:28:25
 Re: Re: Re: Re: Transmission/Hydraulic Fluid in reply to marlowe, 03-31-2001 08:16:20
Guys, thanks for all your advice. I went to my Massey-Ferguson dealer and bought the m1103 stuff. I will change the fluid today. I really appreciate all your help.
Michael Williams
