TEA 20 block heater
Dannyboy
02-28-2008 08:22:01
I would like to install a block heater on my 1953 TEA 20 (Standard 85mm engine).
I assume I would put it in the lower rad hose but need the hose dimension to order the heater. I don't have access to the tractor right now to measure.
Thanks
Dan
Opa A
02-29-2008 13:45:51
 Re: TEA 20 block heater in reply to Dannyboy, 02-28-2008 08:22:01
You can run a circulating heater. Install a pipe nipple in the block at the draincock, or use a tee and and pipe nipple so you can retain the draincock. Run from the block drain throught the heater and return the warm water through the plate with another pipe nipple at the back of the head. G Top
Dannyboy
02-28-2008 10:31:25
Thanks, now according to the parts catalog (Sparex) my choices are 1 1/4" and 1 1/2", so I guess that maybe the hose has a 1/8" flare at the ends?
Dan
Richard L
02-28-2008 09:56:51
According to the parts on this site it is showing the lower radiator hose at 1.375 ID. Hope this is what you needed. I don't know where the heater goes. Richard
