no vacuum
J CANNON
02-26-2008 18:40:21
Thanks to help from some of you good folks, I thought I was about to button up the old TO20. I have replaced the manifold, rebuilt the carb, set the timing and several other projects. I was trying to start it today and it would not even try to start or sputter. The tractor was running 4 months ago when I pulled it into the garage. I placed my hand over the carb to act a a choke to pull fuel into the carb and the engine had no vacuum. What could I have done or not done that would cause the engine to lose vacuum. Also the engine when it was running had a tick near the front of the block, is this normal? Do I need to stop doing tune up type things and start rebuilding? Any help or advice wuld be greatly appreciated.
phil(va)
02-28-2008 05:51:44
 Re: no vacuum in reply to J CANNON, 02-26-2008 18:40:21
You said you set the timing. Exactly what did you do? Could it be way out of time, like 180 degrees out, like if it was set on the exhaust stroke instead of the compression stroke? Just a thought.
J CANNON
02-27-2008 19:30:14
All of the items mentioned had been checked. The valves had been adjusted. I intended on doing a compression check today. Just for kicks I hit the starter and it fired fight up. I have no clue what happened overnight that made it work, but it fired with no hesitation today. One thing I had mentioned and Jerry/MT responded to was a tick in the engine while running. It seems to be in the front of the engine(cylinder closest to the radiator) about midway down near where the cam shaft is. This tractor sat for several years prior to my getting it running. What are the chances this is something that may go away as the tractor runs. The valves have been adjusted. Should I consider a wrist pin may be bad. Though I don't quite think it sounds loud enough for a wrist pin. The lack of suction yesterday is baffling. I'm not quite sure how to proceed with that issue
Jerry/MT
02-28-2008 09:43:08
 Re: no vacuum in reply to J CANNON, 02-27-2008 19:30:14
If it"s running, I would let it get warmed up and then run a compression check. make sure the carb inlet is open to the atmosphere( slide the rubber hose back), make sure the throttle is wide open and remove the spark plugs. The run the compression check. My #1 ticks a little at start up and when I adjusted the valves, #1 intake valve gave me a problem adjusting it. The tick goes away hot. I always adjust my valve hot and running per the manual but gshadel did it both hot and cold and came to the conclusion that the cold setting gave the same results. Did you look at the push rods when you adjusted the valves? If it sat for along time sometimes the valves stick and the push rod can get bent. Don"t know if that will cause a tick but it"s worth a look. the other thing is those little caps on thevalves often come off and that opens up the valve clearance and that might cause some noise. Is the vave train getting oiled? the oil comes up from the rear cam bearing and into the rocker shaft. Are the #1 valves getting oil.
Glad you got it running.
Lance J.
02-27-2008 17:15:56
J Cannon-
You say that you replaced the manifold and rebuilt the carb. When I have the manifold, plenum, or carb off any engine, I always stick a rag into the intake ports of the cylinder head to prevent debris from getting in. Could you have done this and forgot to remove the rag? Or could a foreign object have found its way into the works somehow?
Don Hooks*
02-27-2008 08:42:41
Two things I would give a quick look at:
1. Is the exhaust blocked? You can't generate any vacuum if there is nowhere for it to go.
2. Did you do anything to the camshaft or gear or did you adjust the valves? It would behave the same way if the cam had stopped turning or the valves were open at the wrong time or all the time.
Jerry/MT
02-26-2008 21:10:14
Are you sure the starter is turning the engine over? I can"t imagine how you don"t get any suction! Is the throttle plate open? Is the carb to manifold gasket in place and the bolts tight? That tick may have been a valve needing adjustment. Have you tried a compression check? Even though the engine is cold it could tell you something.
J CANNON
02-27-2008 05:26:31
 Re: no vacuum in reply to Jerry/MT, 02-26-2008 21:10:14
Yes, the starter is turning the engine. The carb and manifold are on correctly. I had not thought of a compression check. I will work on that today. I appreciate your reply.
