starte switch
ford-s
02-23-2008 05:28:25
can some one tell me the voltage that my starter should be recieving.I have a '51 to-20 that's been converted to 12v.my problem is the starter switch is getting too much voltage,and I would like to put a fuse in to cut the voltage.I would like to run a wire from the battery to the switch,then from the switch to the starter,but I need to know what size fuse to use.cw
Irv (Ia)
02-26-2008 07:06:55
 Re: starte switch in reply to ford-s, 02-23-2008 05:28:25
All the replies are correct on the relay but I wholeheartedly agree with Jerry on using the original start switch. When I got mine it also had a relay on it, and wire hanging everywhere. I cut it all off, put it back to original with a new start switch and its unfailing, especially with a 12v. system. Besides that, the safety of the original is unbeatable. $14.00 and 10 minutes and you're good to go. Irv*
Bob (Aust)
02-24-2008 22:52:37
Australia and America - a common heritage, divided by a common language!! :lol:
I guess you are correct, a starter solenoid switch could also be called a starter relay. I'm still coming to grips with the term "Zerks" for what we call grease nipples.
The more I think about your problems, I'd start with checking all wire terminals are clean and bright and shift the battery earth/ground negative lead to the engine. If that does not fix your problem and the engine starts if you jumper across the starter solenoid/relay (or direct from the battery positive to the starter), then I suspect your solenoid has passed it's "use by" date.
You may give some thought to converting back to the original gear shift starter switch and forget about a solenoid/relay.
Good luck.
Bob in Oz
ford-s
02-24-2008 13:42:05
thanks bob,you're right,I was using 'relay switch'because I went to an auto parts store and ask for it and they called it a relay.I am going to rewire the system,with the ford swich this week.thaks alot for all the help.cw
Bob (Aust)
02-24-2008 12:12:27
I guess you can call it a relay but I think you are referring to the starter solenoid switch (at least that is what it is called in Australia!). If you were using the original transmission lever start, you would not need the solenoid. A fuse anywhere is not going to help you.
As it starts if you jump across the solenoid, it sounds like your earth may be OK, although you should check all connections are clean, bright and tight at the battery, solenoid, starter and where the battery earth (negative) connects to the tractor. If the negative is connected behind the tractor dash, move it to one of the starter motor mounting bolts (or anywhere on the engine). Ferguson tractors are notorious for a bad earth/ground when the earth lead is connected to the back of the dash.
If the solenoid is activating, when you press the starter button you should hear the solenoid energizing with a clicking sound? If the starter motor is not turning over, either your battery voltage is too low (low battery or dirty connections) or the solenoid internal contacts are dirty or burnt out.
Any reasonable 12 volt solenoid should work. If you tried another solenoid and it still didn�t work, it still points to either poor or dirty connection somewhere, or your battery voltage is too low.
The wiring diagram for your tractor is available from the FENA web site.
Bob in Oz
ford-s
02-24-2008 10:46:40
guys I really appreciate your input,my tractor was converted to 12v,alternator years ago,it has been changed to key switch years ago.when I got it back in nov.'07 the plug wires had been cut,I could get it to turn over.I put on new plug wires,plugs,dist.cap,rotor button,and coil.the key switch worked,BUT the RELAY which has a big wire that goes from the relay to the (+)side of the battery,on the other side of the relay a wire goes from the relay to the starter,when I turn the key to start it all I get is a noise,letting me know the electricity is stopping there.when I jump the 2 wires it starts right up,I tried replacing it with a ford relay did not work.I tried a jumper button twice and it burned them out,so I need to know what size fuse to use between the battery,and another button so it won't burn it out.any other suggestions would be appreciated.I have searched for ferguson relay switches and can't find them.thanks for your help,cw
Jerry/MT
02-24-2008 11:41:35
 Re: starte switch in reply to ford-s, 02-24-2008 10:46:40
If I understand you correctly, you don"t need a fuse. You need to wire the relay correctly.
It should have a small wire that runs from the Start terminal on the key switch (it the terminal that is only actuated when you attempt to start. A spring in the key switch returns the key to the Run position and disconnects the solenoid so the starter stops.) When you turn the key to the Start position, the circuit for the solenoid is energized as is the primary ignition circuit.the solenoid closes the contacts between the battery and the starter causing th starter to crank the engine. When the engine starts, you release the key and the key returns to the run position which maintains the primary igniton circuit. if you put a button switch between the battery and the atarter, as Bob pointed out, you have a heck of a big current through the switch and it"s not built for that current so it burns out. Go to www.fergusonenthusiasts.com and look at the circuit diagram there. It may help you understand how to properly hook up the circuit.
Personally, I would go back to the OEM starter switch. They are about $10-15 dollars and they are a much safer and simpler starter switch. You don"t seem to have miuch experience with these old machines and it would behoove you to go back to the OEM system. It basically will do what I think you have tried to do with your "button switch" except the OEM starter switch is designed for high starter current. If you need more help, get back t this forum. You may aslo want to buy ashop manual so you understand more about how the systems on your machine are supposed to function.
Hope this helps you.
Bob (Aust)
02-23-2008 12:22:20
As Jerry said, if you are using the original gear shift lever starter switch, you need maximum current. The starter motor is somewhere around 2 HP, 1,500 watts at 12 volts = 125 amps cranking current. That is an awfully big fuse!!!
Have you converted to a key switch and separate starter solenoid, in which case the solenoid requires and only draws low current to activate?
What do you mean "the starter switch is getting too much voltage"?? It can only receive the battery voltage, which it needs.
Bob in Oz
Jerry/MT
02-23-2008 11:17:41
Are you still using the OEM starter switch that is actuated by the shift lever? And why do you want to reduce the voltage to the starter? You really want all the votage and current you can get to start in cold weather. A fuse will limit current by opening the circuit so I don"t see why you would want that. Afte it blows out, you won"t be able to start because you"ll have an open open circuit untill you replace the fuse. A resistor will reduce the voltage and the current and disipate it as heat whih is wasteful. Are you worried about having a 6 volt starter running on 12 V? I have had one running that way since 1994 and have had no problems with the starter. The current and torque output of the starter are greater than the design point but the crank times are so short that I have never had a problem. Many people on this foum hve similar experiences. You can have your starter rewound to make it a 12v but I really don"t think that is necessary.
RoySC
02-23-2008 08:16:44
The Starter Solenoid is a relay. It receives low amperage current from the battery through the starter button. If you want to add current protection to this circuit by adding a fuse, my guess is a fuse sized at about .5 amp may be about the right size....I'm sure folks on this forum will provide a closer fuse rating in this range.
Good luck!!
