off topic Need a source for coal
John (TR)
02-21-2008 16:35:39
Does anyone know of a source for coal in the Northwestern IL/Southeastern IA area? My dad is looking for some for his farriers forge. Going to use it to heat up my front bumper and straighten it out.
Thanks
John
Don Hooks*
02-22-2008 15:00:48
 Re: off topic Need a source for coal in reply to John (TR), 02-21-2008 16:35:39
My dad used to use charcoal. He wouldn't use briquettes, just the "cheap" stuff and it seemed to work just fine for him. He preferred it to his torch when he wanted a large radius bend or was working on something really thick.
Jeff-oh
02-22-2008 08:09:52
I got 3 - 5 gallon buckets of coal when I bough my forge last fall. I also had a friend who works for Norfolk Southern. The had a big left over coal pile and he would bring buckets full of coal for our scout outings...
Alas, This past summer the RR. got rid of the old coal pile.
Randyr
02-22-2008 13:23:57
 Re: off topic Need a source for coal in reply to Jeff-oh, 02-22-2008 08:09:52
Jeff, were they left over from the days of steam?
I'm surprised the pile lasted that long. I thought people would have helped themselves to it long ago.
Jeff-oh
02-25-2008 05:10:21
 Re: off topic Need a source for coal in reply to Randyr, 02-22-2008 13:23:57
My friend, Told me the yard workers would use it to keep barrels burning for warmth in the winter. It was probally left over from the days of coal stoves in the work buildings.
This was the Sharonville yard.
Randyr
02-22-2008 07:09:25
I looked around but unfortunately the coal dealers are all in the east. This one has dealers in Michigan and Indiana, if that helps. It's not close, you'd have to get a truck or trailer and do some driving.
Link
How about using an oxy-acetylene torch to straighten the bumper? I have bent some pretty heavy steel using one.
John (TR)
02-25-2008 04:20:44
 Re: off topic Need a source for coal in reply to Randyr, 02-22-2008 07:09:25
I prefer oxy/acetelyne which I have. I was using the bumper as a reason to get the forge out but actually prefed using the gas as I could heat very small areas at a time and take out the bends plus it was really handy using gas and the "mandrel" to bend the corners. Just keep working down the piece as it bent around. You have much more control with the torch.
John TR)
02-22-2008 14:13:35
I'm not the Blacksmith my dad is. I'm much happier to use the gas. Dad insists on bringing his forge over which I found 2 years ago ago, tore apart and rebuilt. Its never had a fire in it and he's decided now is the time to try it out
. I've got some junk steel for him to heat. I actually prefer the torch as I can heat a much smaller area at a time and its more controlled which is particularly handy beding iron around a mandrel
I try and only talk Fords on the Ford board and Fergs on the Ferg board as I have both. Here is a bumper I'm working on for my Fords. I have 2 of these.
Typical bent bumper, sprung too wide, bars bent and missing
third party image
Frame straitened
third party image
Uprights straitened, cross piece strait now
third party image
third party image
Home grown mandrel for bending new bars
third party image
Crem
02-22-2008 18:06:59
 Re: off topic Need a source for coal in reply to John TR), 02-22-2008 14:13:35
John, you have some good ideas there. Have you figured out a way to make some original looking rivets? I need to put two rivets in a bumper that I have.
John (TR)
02-25-2008 04:17:02
 Re: off topic Need a source for coal in reply to Crem, 02-22-2008 18:06:59
I used real rivets. I've not been able to find them locally for some time so I looked on ebay and found them there. The rivet setting tool is for the back side. The seller also had a backing plate which is a small 1.5" sq plate with a couple of different rivet head sizes cut into ti and youplace the new rivet in the material, set the piece on something solid with the head in the backing plate, clamp it down, heat the protruding end of the rivet untill brisght orange and hit is with a setting tool and a 3lb hammer. Its a Ford but figured the process is the same.
after rebuild, before paint
third party image
mounted on my '40 Ford/Ferguson
third party image
