Oil Pressure TEA20
Matt
03-27-2001 00:32:14
I have just brought a TEA-20, the oil pressure guage reads 60 for the first 5 mins then drops to just above 0 and after about half an hour it drops to 0, does anyone have any ideas on what the problem may be or if this is normal.
any help would be much appriecated
dave
03-29-2001 17:23:19
 Re: Oil Pressure TEA20 in reply to Matt, 03-27-2001 00:32:14
Matt, There is an adjustment at the filter housing for pressure. loosen the lock nut and turn a couple of turns in. This should raise the pressure. Goodluck.
D
steveuk
03-27-2001 11:13:02
try changeing the oil , TEA oil often gets diluted with fuel
PETERC
03-27-2001 04:30:27
it sounds like bearing wear as heat builds the clearances get bigger and the oil pressure drops. You can check the oil press relief valve but it is usually engine wear.
