TO 30 skip in motor
Peter Blake Sr.
03-25-2001 14:08:31
My TO30 has a skip when idoling and at full speed but under a load it levels out and run perfect any ideas
stevie_alc
03-25-2001 19:28:25
 Re: TO 30 skip in motor in reply to Peter Blake Sr., 03-25-2001 14:08:31
Are you on 6 or 12 volt? Mine used to be that way untill I went to alternator and 12 volt coil. The skip had nothing to do with carburation on mine.
peterc
03-25-2001 16:36:53
it may be running to rich if it stops missing under load,try adjusting the carb and see if that helps
Peter Blake Sr.
03-25-2001 16:48:47
 Re: Re: TO 30 skip in motor in reply to peterc, 03-25-2001 16:36:53
Thanks I just rebuilt the carb and played with it for a while cant seem to get it right do you know what the settings shuold be ?
Ray,IN
03-25-2001 18:51:20
 Re: Re: Re: TO 30 skip in motor in reply to Peter Blake Sr., 03-25-2001 16:48:47
In my experience this is usual. The carb should be adjusted for the best performance under load. Adjusted properly the engine will need a richer fuel mixture under load to help cool the valves and combustion chamber. I would leave the power mixture alone, and adjust the idling air screw only. The only thing that can happen is carboning of the spark plugs and combustion chamber with prolonged idling. You may consider adding a good fuel system/carb cleaner to the gas tank before next filling. The gas we are forced to use today goes bad in just a few weeks, gumming and varnishing the jets,valves,seats and the entire fuel system in general. Once I got the proper carb settings, this was the only problem I've had in 11yrs. My 2 cents
Jim
03-31-2001 09:23:04
 Re: Re: Re: Re: TO 30 skip in motor in reply to Ray,IN, 03-25-2001 18:51:20
There are two adjusting Screws on the Carb one has a screwdriver slot, the other can be turned with fingers which is which and where is a good initial starting place for both of these screws?
Peter B Sr.
03-26-2001 15:52:48
Thanks Ray I'll try that. I love my tractor!!!!
