Oil Pressure
Hal Hadaller
02-18-2008 16:11:24
Does the shim between the oil pump and bearing cap act as a gasket, such that if there was no shim, the oil would leak thru the contact area? I am only getting about 10 PSI and no oil up to the rocker arm sssembly. Engine fired right up on first flipover but did not run it long due to this problem. Have new crank, bearings, etc.
Don Hooks*
02-18-2008 21:06:11
 Re: Oil Pressure in reply to Hal Hadaller, 02-18-2008 16:11:24
Hal,
My pump also had a stuck plunger but since I had to replace the gears and the kit had a new one I used it. The old one would not have cleaned up enough to reuse because, by the time it would be smooth, it would have too much bypass. That may be part of your problem but I have to ask if the camshaft was removed (either this time or by the former owner)? There is an orifice in the retainer that meters oil flow from the gallery into the timing gear cover and if it was damaged or, heaven forbid, drilled out, all your oil would dump right back into the pan and the signal to the guage would be low.
Hal Hadaller
02-19-2008 06:09:53
 Re: Oil Pressure in reply to Don Hooks*, 02-18-2008 21:06:11
I tore the engine down to the BARE block so Camshaft was out and checked. But I don't understand the statement about "orifice in the retainer that meters oil flow from the gallery into the timing gear cover". One of my manuals mentions a 5/32" vent hole behind the number 1 cylinder exhaust cam follower. I guess that this is what you are talking about. Seems that the manuals concern is that the hole is blocked and the governor would not operated properly. Why would anyone have drilled this out? Seems that the opening is in the casting of the block.
Jerry/MT
02-18-2008 19:57:01
If your bearings are within specs and you are not deelopeng between 25-30 psi oil pressure,in my opinion, your pump clearances are too big or the relief valve is open or both.
I"d make sure that the relief valve was functioning properly first. It sounds like like it was in bad shape and you did a lot of work on it. There are some clearance to be checked on the oil pump. Of course it will "look good" because it"s running in oil. If the clearances are excessive it won"t develop enough pressure and flow. The clearance between the gear and the housing shouuld be between 0.003-0.004" with a new drive gear. If it exceeds 0.005", replace the bushing. There are additional specs on back lash but it"s to lengthy for me to write up here. If you have the shop manual, you can read it there.
There is a long passage in the block from the rear cam bearing that supplies oil to the rocker shaft. Run a wire down that to make sure that is not plugged. I would only do this if you get 25-30 psi oil pressure and the top end isn"t oiling.
Hal Hadaller
02-18-2008 20:17:54
 Re: Oil Pressure in reply to Jerry/MT, 02-18-2008 19:57:01
Thanks, Jerry. I am covinced that something is wrong with the pump area. I even put in a new lead gasket, polished the face plate on a FLAT surface. I even polished the relief valve with valve grinding compound, and checked the spring tension. Brand new crank and new snug fitting bearings. There was virtally play in the pump shaft bushing or between the gears. I presume that he swivel on the oil pickup is below the oil level (just thinking about this at this moment of writing). Pulling the pan in the morning.
gshadel
02-18-2008 18:41:25
The shims are for adjusting the backlash between the oil pump gear & the crankshaft gear, not as gasket material. Even if you did have some leakage, it would take quite a bit of leakage to cause low pressure with a good pump, and would be surprising to get much leakage when torqued to 90 ft pounds. But if you are in doubt, you can pull the pump, and clean-up the mating surfaces.
Did you rebuild the oil pump? If no, that may be your problem, Also verify that your oil intake tube is sealed tightly at the connections and not sucking air.
Did you mic the crank & bearings yourself... or taking the word of someone else that they are to spec? If the pump system is good, that is the next likely culprit. Plastigauge thread works real good to check the oil clearances in the crank bearings.
George
Hal Hadaller
02-18-2008 19:10:13
 Re: Oil Pressure in reply to gshadel, 02-18-2008 18:41:25
New crank, bearings, etc. Torqued to 85 ft lbs. I had the oil pump apart and unstuck the plunger, used valve grinding compound on the plunger seat, checked the spring tension, cleaned the plunger hole so the plunge moved freely, (it was really bad), replaced the lead gasket with a new lead one, tightened the suction line fitting securely, but did not check anything else on the suction pickup assembly. Pump oil gears looked like new. 5 quarts of oil in the pan. I did not remove the oil gauge to check for oil coming out but I had a good 10 psi. But not a drop on top for the rocker arms (took plug off shaft end) with engine running.
Am dropping the pan in the morning to recheck things but at a loss at this moment and also surprised that that this is happening. The engine originally had major "lack of oil problems" in the bearings, etc., so whatever else is wrong could still be there. I flushed out the block GOOD with chemicals but could not open the galleys as the plugs at the end were STUCK. Even an impact wrench would not loosen them, and I did not want to drill the pipe plugs out. So blew air threw everything in the internal oil lines that I could think of and no blockages anywere. The only thing between the pressure gauge port and the pump is NOTHING but the galley itself - and of course, the relief valve maybe being open for some unknown reason. Will check the mating surface. Thanks for the fast reply.
