Installing PTO shaft in TO 30
Herb Rush
02-13-2008 06:34:07
I am getting ready to install new PTO shaft, bearings, and gaskets in a Fergason TO 30 any body have any recomdations or tips
ferg0ne
02-13-2008 16:53:30
 Re: Installing PTO shaft in TO 30 in reply to Herb Rush, 02-13-2008 06:34:07
I put the 1 1/8 back in my To30 so I could put a belt pulley on for a buzz saw put front down hill and took the 4 nuts off and just pulled the shaft out I will put the 1 3/8 back if I have to use a mower this is a easy switch long as the shaft is not twisted in the coupling
phil(va)
02-14-2008 07:01:06
 Re: Installing PTO shaft in TO 30 in reply to ferg0ne, 02-13-2008 16:53:30
For about $20 or so you can buy a coupling that converts the 1 1/8 to 1 3/8.
herb rush
02-13-2008 06:58:57
Thanks for the info, i looked for the other posts on this subject i didn't see them, do you know were there at ?
Chuck (CA)
02-13-2008 20:00:07
 Re: Installing PTO shaft in TO 30 in reply to herb rush, 02-13-2008 06:58:57
Click on the link and it hopefully will get you started
Chuck
Richard L
02-13-2008 09:41:51
From what I have seen about removing and replacing a pto shaft on this forum it is not hard at all. Like Phil said you may have to hook something to the shaft to get it started out then the new one should slide right in. I haven't had to do that yet just what I have read. You asked where to find that on here. In the SEARCH FOR box type in "pto removal"
then click GO and you should have several threads to read. Good Luck
phil(va)
02-13-2008 06:41:02
Lots of previous posts on this subject. One method, if you are not replacing the fluid at the same time, is to drive the front of the tractor into a ditch to keep from losing much fluid. Old shaft should pull out easily, but if it doesn"t try hooking something onto it like the PTO connection off a bush hog to give you more leverage as you pull.
