TO30 Steering Box Seals
Lou Ky
02-12-2008 10:52:48
I'm restoring a TO30 that set in the barn with a bad crank for 10 yaers, I've got the engine rebuilt. painted, "frame painted, ready to start putting it together. I seam to remember the two shafts/arms coming out of both sides of the steering box leaked a little oil/gease. Now with all this shiney grey paint, I don't want it messed up with a leaking steering box. I'm not finding any place on line selling seals for these two arms, can someone educate me? I guess I should have bought a parts manual a long time ago. Ha!
Thanks Lou
Bob (Aust)
02-12-2008 19:05:28
 Re: TO30 Steering Box Seals in reply to Lou Ky, 02-12-2008 10:52:48
[quote:370bd05053]��have to take steering arms completely out of both sides. Then you need to follow manual on re-setting the tension and mesh.�[/quote:370bd05053]
If the TO20/30 steering box is the same as the TEA20, you don�t need to disassemble the steering box to change the drop arm seals.
Grind off the centering nipples on the drop arms and the old seal will slip over the drop arm �shoulder� and new seal will fit on the same way, in reverse.
Bob in Oz
mark from the fort
02-13-2008 11:16:07
 Re: TO30 Steering Box Seals in reply to Bob (Aust), 02-12-2008 19:05:28
Correct, but since he has his tractor already painted--I didnt think grinding the tab off was a good idea.
Mark
mark from the fort
02-13-2008 11:16:09
Mark
Mark from the fort
02-12-2008 13:36:53
OR, Pump her full of John Deere Cornhead grease.
It comes in tubes and is very thin, YET, will not run out of seal.
That is assuming there are some seals still in there. I put about 6 tubes in my TO30 and works fine.
Actually make for higher rpms, so a steering gears are MORE than protected. Mark
--If ya go the new seal route (which isnt difficult) you have to take steering arms completely out of both sides. Then you need to follow manual on re-setting the tension and mesh.
Mark
Steve (PA)
02-13-2008 17:56:55
 Re: TO30 Steering Box Seals in reply to Mark from the fort, 02-12-2008 13:36:53
Yup, I did the same thing. If you heat the cartridges in a bucket of hot water, they will pour through a funnel. No leaks or drools yet.
joe in tn
02-12-2008 13:10:27
I can help you with those seals. any auto parts store should be able to get them. the original chicago rawhide number is: 13027. But that changes up to a Federal Mogul National number of: 473423 I bought mine at O'reiley's auto parts store. I hope that helps.
Lou Ky
02-12-2008 13:44:46
 Re: TO30 Steering Box Seals in reply to joe in tn, 02-12-2008 13:10:27
Thanks Joe
That's great, I've got an O'Reilys in town.
Lou
Richard L
02-12-2008 11:25:18
Lou, on this site left side of page under MARKET PLACE click on tractor parts I am not positive but I think they have what you are looking for. If you can't see them there email or call them. Richard
