TO 30 temp gauge tube wire
guyeli
02-10-2008 15:01:36
While tinkering w/my To 30 I managed to accidently
break the wire from my sending unit to my temp gauge.The sending wire was wrapped inside a coil of
another wire,but was about two feet too long and the extra got in the way and got snagged and broke.Now I have about 12" coming from the temp gauge and about 3'coming from the sending unit.My question is can I simply connect the wire from the sending unit directly to the temp gauge? or do I need to get a whole new assembly (wire and guage)? I am not very familiar w/the wiring regarding these temp gauges and do not understand the process of connecting the wire to the gauge.Any advice would be appreciated.Thanks.
Jerry/MT
02-10-2008 15:58:05
 Re: TO 30 temp gauge tube wire in reply to guyeli, 02-10-2008 15:01:36
The temperature gauge you are using is a capillary tube gauge that uses alchohol, I believe, to mechanically move the temperature gauge. When you broke the tube, the alchohol evaporated. In the Restoration Forum, there are instructions on how to repair them. Personally, I"d just spend the $15-20 and buy a replacement which consists of the sensing bulb, the tubing and the guage as all one unit.
Gerald J.
02-10-2008 15:08:52
That's usually NOT a wire, but a fine tube with gas under pressure. You've let the gas out now and the only replacement is a gauge, tube, and bulb assembly.
Gerald J.
