Sabilizer bracket swivel ball
Hal Hadaller
02-09-2008 19:39:10
I have 2 styles of stabilizer brackets under my fender mounting bolts. One is normal with 1 hole for the pin. The other is longer and has the hole and then a swivel ball outward of that about 2 inches. What is this for? The stabilizer brakets pins are designed to be opposite the swing arm mounting pins on the same dimensional center.
Fred T. Hart Jr.
02-10-2008 16:37:20
 Re: Sabilizer bracket swivel ball in reply to Hal Hadaller, 02-09-2008 19:39:10
I believe ArleninOR is correct, it is used on the Dearborn mowing machine.
If you take it off you can no longer hook up your mower. Need to find a Dearborn mower and you will have a true set.
Fred T. Hart Jr.
02-10-2008 16:37:12
ArleninOr
02-10-2008 15:06:32
That bracket if I remember right was for the breakaway bracket on a dearborn cycle bar mower.I have some of those and a mower that came with one.
Hal Hadaller
02-10-2008 19:33:13
 Re: Sabilizer bracket swivel ball in reply to ArleninOr, 02-10-2008 15:06:32
Guess I may just mount the swivel ball bracket during my final assembly in the up-coming month. It will be more authentic anyway. And I could use a sickle mower; if I can find one reasonable. Progress has been good on the tractor now as things are starting to come together. Coupled up the completely rebuilt engine this weekend, so looking a little like a tractor now. It has been a long 6 months working every day some on the project. But I did not cut any corners and attended to just about EVERYTHING that could be broken or in need of repair.
MattMalcome1
02-10-2008 06:20:57
I had the same question. I have a 43 2N that has the same bracket you describe on the right, and a normal one on the left. I also have a spare one, right side only. I wonder if there is a ball style left bracket?? The spare bracket did come with a Ferguson TO-30 a while back, could it be Ferguson only, just happen to have one on a Ford??
Don Hooks*
02-09-2008 20:37:12
I asked one "even-older-than-me" oldtimer and he said that the side mounted Ferguson implements used it but I've never seen anything that might use it except a mower. I suspect it might be handy for anchoring a front blade.
Hal Hadaller
02-10-2008 07:23:55
 Re: Sabilizer bracket swivel ball in reply to Don Hooks*, 02-09-2008 20:37:12
Seems that I am not the only one with such a bracket. Think I will omit putting this on my COMLETELY restored Ferguson and find a standard LH Bracket. Thank all of you for your inputs.
Kirk-NJ
02-10-2008 09:09:36
 Re: Sabilizer bracket swivel ball in reply to Hal Hadaller, 02-10-2008 07:23:55
Hal, I have them on both my 1951 TO30 and my 1950 ford 8N. So I guess they were pretty common. Kirk
